Prius Air Conditioner Compressor Drives Cable Winch
In addition to its fuel efficiency and legendary reliability, the Toyota Prius has a number of things going for it that make it an extremely useful car to own. It can be easily converted into a capable generator that also functions as transportation, and makes a good stealth camping setup since its climate control can run off of the battery in some situations. But beyond keeping it in tact as a usable vehicle with special use cases, its various electrical parts are increasingly finding themselves in all kinds of unusual scenarios as well. [Jeremy] used the electric compressor from one’s air conditioning system to instead drive a winch on his electric Jeep conversion.
The winch that [Jeremy] got was by way of an online classified ad, by way of sitting outside unused on a trailer for a number of years. So there was a bit of renovation that needed to happen, which included tearing the entire mechanical system down and restoring it part-by-part. That doesn’t solve the main problem with this winch, though, because it was originally set up to use a 12V motor. This isn’t an issue on a standard vehicle with a large 12V battery, but his Jeep conversion has a small 12V battery that wouldn’t drive the winch very well. Noticing that he has a large 400V battery also, he set about converting the winch to use that instead.
A compressor for a Prius is already designed to run on higher voltage, plus the Prius electronics he’s using already have a readily-accessible way to deliver power to it, so he mostly only needed a coupler for this motor to mate to the winch. A side effect of this modification is that much smaller cables are needed for the same amount of power delivered. The gearbox in the winch has around a 300:1 gear reduction so the compressor motor had more than enough torque to pull the Jeep around even with the brakes applied.
