The Wow! signal represented as "6EQUJ5" with Jerry R. Ehman's handwritten comment.
Listening For The Next Wow! Signal With Low-Cost SDR
As you might expect, the University of Puerto Rico at Arecibo has a fascination with radio signals from space. While doing research into the legendary “Wow! Signal” detected back in 1977, they realized that the burst was so strong that a small DIY radio telescope would be able to pick it up using modern software-defined radio (SDR) technology.
This realization gave birth to the Wow@Home project, an effort to document both the hardware and software necessary to pick up a Wow! class signal from your own backyard. The University reasons that if they can get a bunch of volunteers to build and operate these radio telescopes, the resulting data could help identify the source of the Wow! Signal — which they believe could be the result of some rare astrophysical event and not the product of Little Green Men.
Ultimately, this isn’t much different from many of the SDR-based homebrew radio telescopes we’ve covered over the years — get a dish, hook your RTL-SDR up to it, add in the appropriate filters and amplifiers, and point it to the sky. Technically, you’re now a radio astronomer. Congratulations. In this case, you don’t even have to figure out how to motorize your dish, as they recommend just pointing the antenna at a fixed position and let the rotation of the Earth to the work — a similar trick to how the legendary Arecibo Observatory itself worked.
The tricky part is collecting and analyzing what’s coming out of the receiver, and that’s where the team at Arecibo hope to make the most headway with their Wow@Home software. It also sounds like that’s where the work still needs to be done. The goal is to have a finished product in Python that can be deployed on the Raspberry Pi, which as an added bonus will “generate a live preview of the data in the style of the original Ohio State SETI project printouts.” Sounds cool to us.
If you’re interested in lending a hand, the team says they’re open to contributions from the community — specifically from those with experience RFI shielding, software GUIs, and general software development. We love seeing citizen science, so hopefully this project finds the assistance and the community it needs to flourish.
Thanks to [Mark Stevens] for the tip.
WOW! It Wasn’t Aliens After All!
There may not be many radio astronomy printouts that have achieved universal fame, but the one from Ohio State University’s Big Ear telescope upon which astronomer [Jerry R. Ehman] wrote “WOW!” is definitely one of them. It showed an intense one-off burst that defied attempts to find others like it, prompting those who want to believe to speculate that it might have been the product of an extraterrestrial civilization. Sadly for them the Planetary Habitability Laboratory at the University of Puerto Rico at Arecibo has provided an explanation by examining historical data from the Arecibo telescope.
The radio signal in question lay on the hydrogen line frequency at 1420 MHz, and by looking at weaker emissions from cold hydrogen clouds they suggest that the WOW! signal may have come from a very unusual stimulation of one of these clouds. A magnetar is a type of neutron star which can create an intense magnetic field, and their suggestion is that Big Ear was in the lucky position of being in the right place at the right time to see one of these through a hydrogen cloud. The field would excite the hydrogen atoms to maser-like emission of radiation, leading to the unexpected blip on that printout.
There’s a question as to whether speculation about aliens is helpful to the cause of science, but in answer to that we’d like to remind readers that we wouldn’t be talking about magnetars now without it, and that the WOW! signal was in fact part of an early SETI experiment. Better keep on searching then!
Meanwhile readers with long memories will recollect us looking at the WOW! signal before.
The Wow! Signal Revisited: Citizen Science Informs SETI Effort
As far as interesting problems go, few can really compete with the perennial question: “Are we alone?” The need to know if there are other forms of intelligent life out there in the galaxy is deeply rooted, and knowing for sure either way would have massive implications.
But it’s a big galaxy, and knowing where to look for signals that might mean we’re not alone is a tough task. Devoting limited and expensive resources to randomly listen to chunks of the sky in the hopes of hearing something that’s obviously made by a technical civilization is unlikely to bear fruit. Much better would be to have something to base sensible observations on — some kind of target that has a better chance of paying off.
Luckily, a chance observation nearly 50 years ago has provided just that. The so-called Wow! Signal, much discussed but only occasionally and somewhat informally studied, has provided a guidepost in the sky, thanks in part to a citizen scientist with a passion for finding exoplanets.
Continue reading “The Wow! Signal Revisited: Citizen Science Informs SETI Effort”
