There’s A Whole Computer Inside This Mouse
[Gadget Industry] bills it as “a PC inside a Mouse“, but that depends on your definition of a “PC”. This is a Personal Computer inside a mouse, yes, but there’s nothing IBM-compatible about the tiny ARM board he squeezes inside what’s normally a peripheral — it actually started life as a smartphone, which only takes this build up a notch compared to starting with a single-board computer like a Pi.
Specifically, he starts with a Galaxy S21 5G. Starting with a Samsung means he can leave the stock Android alone and just take advantage of Samsung’s DeX desktop mode, rather than layer a Linux environment on top or replace the operating system entirely with something like Postmarket OS, which are both viable options.
Continue reading “There’s A Whole Computer Inside This Mouse” →
Ergonomic Mouse Gives Each Fingertip Its Own Saddle
Want to make your own ergonomic mouse but don’t know where to start? Why not try [psudoku]’s Kotinos design?
It’s a scaffold-like fingertip shell that uses the internals of an HSK Pro mouse. Each fingertip gets its own little saddle-shaped nook, and things like hand size and paddle surface can all be configured by modifying the OpenSCAD scripts.
[psudoku]’s unit looks to us as though it was maybe made using multi-jet fusion (MJF) 3D printing, but it should be perfectly printable on hobbyist printers, whether resin- or filament-based.
Comfort of the contact surfaces is left up to the end user, but if your print lacks smoothness and sanding isn’t your jam, you might consider a layer of fabric tape to create a velvet-like surface on a 3D print. That’s a trick we’ve kept in mind ever since seeing it put to good use, cushioning the hardware in a DIY steam deck case.
Is the minimalist scaffold approach to a mouse not your style, or does your hand crave something less lightweight but a little more personalized? You might want to craft a truly custom-fitted mouse, for which clay is the way.
