An image of a smarphone sitting on a lightly-colored wooden table. It has a tan case surrounding it on the top 2/3, and a copper case holding a BlackBerry Q10 keyboard jutting out over the bottom of the phone.
FairBerry Brings The PKB Back To Your Smartphone
Missing the feel of physical keys on your phone, but not ready to give up your fancy new touchscreen phone? [Dakkaron] has attached a BlackBerry keyboard to a slightly more recent device.
Designed for the FairPhone 4, [Dakkaron]’s hack should be transferable to other smartphones as it connects to the phone over USB without any of that tedious mucking about with Bluetooth. There’s even a handy OpenSCAD-based generator to help you along in the customization process.
[Dakkaron] started with an Arduino Pro Micro-based implementation, but the most recent iteration uses a custom board that can be obtained partially-populated. Unfortunately, the Hirose connector for the keyboard isn’t available off-the-shelf, so you’ll have to solder that yourself if you’re planning to do this mod. Sounds like a perfect opportunity to practice your surface mount soldering skills!
If the Q10 keyboard looks familiar, it’s probably because it’s one of the most popular keyboards for small projects around here. Check out Regrowing a BlackBerry from the Keyboard Out or a LoRa Messenger with one. We’ve even seen them in a conference badge!
Regrowing A Blackberry From The Keyboard Out
Here at Hackaday we’re big fans of device-reuse, and what [arturo182] has done with the Blackberry Q10’s keyboard is a fantastic example. Sometimes you’re working on a portable device and think to yourself “what this could really use is a QWERTY keyboard”. What project doesn’t need a keyboard?
Typically this descends into a cost benefit analysis of the horrors of soldering 60ish SMD tact switches to a board, which is no fun. With more resources you can use Snaptron snap domes like the [NextThingCo’s] PocketCHIP, but those are complex to source for a one off project and the key feel can be hard to really perfect. Instead of choosing one of those routes, [arturo182] reverse engineered the keyboard from a Blackberry Q10.
When you think of good, small keyboards, there has always been one standout: Blackberry. For decades Blackberry has been known for absolutely nailing the sweet tactile feel of a tiny key under your thumb. The Q10 is one example, originally becoming avalible in 2013 as one of the launch devices for their then-new Blackberry OS 10. Like most of Blackberry’s business the OS and the phone are long out of date, but that doesn’t mean the keyboard has aged.
[Arturo182] says he can find them from the usual Chinese sources for around $3 each, which is too cheap to not explore. Building on the work of [WooDWorkeR] (on Hackaday.io) and [JoeN] to reverse engineer the matrix and to find the correct connector, he integrated the keyboard into an easy to use breakout board that exposes the key matrix, per-row backlight controls, and even the MEMS mic! More excitingly, he has built a small portable device with all the trappings of the original Q10; a color LCD, joystick, function buttons, and more in a very small footprint.
KiCAD sources, including 3D models, for the keyboard and for the breakout board are available.
Now if only someone can find a way to salvage the unusual square, high-DPI displays from the Q10, we’d be in portable device nirvana.
Continue reading “Regrowing A Blackberry From The Keyboard Out” →
Gaming Keyboard Features Incredible Workmanship
Gaming Keyboard in Desk
Hello people, look at your keyboard, now back to this one, now back to your keyboard, now back to us. Sadly, your keyboard isn’t this one, but if you’re handy with wood and metalwork, it could look like this one!
This incredible keyboard was made with the blood, sweat, and tears of [Kurt Plubell], an architectural draftsman. He began a few years ago when he hung up his T-square and started using CAD for his work. His biggest complaint about CAD? Ergonomics! His setup slowly evolved as he was determined to find the most comfortable way to work. First, a keyboard and a trackball. Then, a keyboard, a trackball, and a left-handed mouse. Then, an ergonomic keyboard on a desk mounted tray (and trackball + mouse) — he still wasn’t satisfied. Thus began his journey into a fully customized setup.
He started with the ErgoDox keyboard, which is a two-part ergonomic keyboard. He ordered the aluminum version, which isn’t quite as nicely finished as you would think — but we doubt the manufacturer was expecting its consumers to be taking it apart and integrating it into something else. A lot of sandpaper, die grinding and polishing later, and it had a much nicer finish.
The keyboard was built up using wood and MDF, and finally finished with a very nice wood veneer, giving a very executive finish to the project. He’s integrated four arcade buttons and a Kensington track ball in the very middle — and of course, being a true typist, his keys have no markings.
[via Reddit]
