Hackaday Links Column Banner
Hackaday Links: August 31, 2025
Back in March, we covered the story of Davis Lu, a disgruntled coder who programmed a logic bomb into his employers’ systems. His code was malicious in the extreme, designed as it was to regularly search for his Active Directory entry and fire off a series of crippling commands should it appear he had been fired. His 2019 sacking and subsequent deletion of his AD profile triggered the job, wreaking havoc on servers and causing general mayhem. Whatever satisfaction Lu drew from that must have been fleeting, because he was quickly arrested, brought to trial in federal court, and found guilty of causing intentional damage to protected computer systems.
Lu faced a decade in federal prison for the stunt, but at his sentencing last week, he got four years behind bars followed by three years of supervised release. That’s still a pretty stiff sentence, and depending on where he serves it, things might not go well for him. Uber-geek Chris Boden has some experience in the federal prison system as a result of some cryptocurrency malfeasance; his video on his time in lockup is probably something Mr. Lu should watch while he can. Honestly, we feel bad for him in a way because we’ve been there; we certainly toyed with the logic bomb idea when we were coding for a living, without actually ever doing it. Maybe he thought it would just get treated as a prank, but that was probably never in the cards; as we’re fond of telling our kids, the world just doesn’t have a sense of humor anymore.
Continue reading “Hackaday Links: August 31, 2025”
Retrotechtacular: Ford Model T Wheels, Start To Finish
There’s no doubt that you’ll instantly recognize clips from the video below, as they’ve been used over and over for more than 100 years to illustrate the development of the assembly line. But those brief clips never told the whole story about just how much effort Ford was forced to put into manufacturing just one component of their iconic Model T: the wheels.
An in-house production of Ford Motors, this film isn’t dated, at least not obviously. And with the production of Model T cars using wooden spoked artillery-style wheels stretching from 1908 to 1925, it’s not easy to guess when the film was made. But judging by the clothing styles of the many hundreds of men and boys working in the River Rouge wheel shop, we’d venture a guess at 1920 or so.
Production of the wooden wheels began with turning club-shaped spokes from wooden blanks — ash, at a guess — and drying them in a kiln for more than three weeks. While they’re cooking, a different line steam-bends hickory into two semicircular felloes that will form the wheel’s rim. The number of different steps needed to shape the fourteen pieces of wood needed for each wheel is astonishing. Aside from the initial shaping, the spokes need to be mitered on the hub end to fit snugly together and have a tenon machined on the rim end. The felloes undergo multiple steps of drilling, trimming, and chamfering before they’re ready to receive the spokes.
The first steel component is a tire, which rolls down out of a furnace that heats and expands it before the wooden wheel is pressed into it. More holes are drilled and more steel is added; plates to reinforce the hub, nuts and bolts to hold everything together, and brake drums for the rear wheels. The hubs also had bearing races built right into them, which were filled with steel balls right on the line. How these unsealed bearings were protected during later sanding and grinding operations, not to mention the final painting step, which required a bath in asphalt paint and spinning the wheel to fling off the excess, is a mystery.
Welded steel spoked wheels replaced their wooden counterparts in the last two model years for the T, even though other car manufacturers had already started using more easily mass-produced stamped steel disc wheels in the mid-1920s. Given the massive infrastructure that the world’s largest car manufacturer at the time devoted to spoked wheel production, it’s easy to see why. But Ford eventually saw the light and moved away from spoked wheels for most cars. We can’t help but wonder what became of the army of workers, but it probably wasn’t good. So turn the wheels of progress.
Continue reading “Retrotechtacular: Ford Model T Wheels, Start To Finish”
a modern car dipped into a chemical bath for electrodeposition adding a phosphate layer
Watching Paint Dry For Over 100 Years
A Model T Ford customer could famously get their car “in any color he wants, so long as it’s black.” Thus begins [edconway]’s recounting of the incremental improvements in car paint and its surprising role in mass production, marketing, and longevity of automobiles.
In it, we learn that the aforementioned black paint from Ford had so much asphalt in it that black was the only color that would work. Not to go down a This Is Spinal Tap rabbit hole, but there were several kinds of black on those Model Ts. Over 30 of them were used for various purposes. The paints also dried in different ways. While the assembly only took 12 hours, the paint drying time took days, even weeks backing up production and begging for innovation. [edconway] then fast-forwards to an era of “conspicuous consumption and ‘planned obsolescence’” with DuPont’s invention of Duco that brought color to the world of automobiles.
edconway graph of paint drying time by year
See the article for the real story of advances in paint technology and drying time. Paint application technology has also steadily improved over the years, so we recommend diving in to get the century’s long story.
Museums Should Be More Popular Than Theme Parks
One of the field trips that we set up as part of our Detroit tour was a trip to The Henry Ford Museum. After a rather disappointing first half hour wandering around the static exhibits of nicely polished cars we latched onto the part of the museum that’s starts the serotonin pump for anyone who is engineering-minded. There are amazing displays of early industrialization, including steam engines for factories, early power generators, and examples of early assembly line machinery. We’re going to cover that stuff in depth but editing it all together will take some time.
For now we wanted to give you a quick glimpse at a delightful exhibit of a Model T. You don’t just look at it; every morning the museum staff takes apart the entire vehicle and throughout the day helps museum-goers walk through the process of putting it back together.
Why isn’t this the model to supplant amusement parks? This hands-on work with real equipment — not just a model made to stand up to the masses — is pure gold for occupying curious people of all ages. The interaction with museum staff adds a tangible human element to the institution, and you just might learn something more than history in the process!
[Full Disclosure: The Henry Ford provided Hackaday with free admission — Thank You!]
