NES Advantage Stick Gets Bluetooth Upgrade
The NES Advantage was a cool bit of hardware back in 1987, bringing an arcade stick to the home console gaming experience. Naturally they don’t get much use these days, unless of course they’ve been modded to work with modern systems, as [Aaron] has done.
[Aaron]’s goals were straightforward. The stick should work with modern systems over Bluetooth, but the mod should not involve cutting the case or making any new holes. All controls, including Turbo and Slow Motion, still had to work, too, and there would be no adding extra buttons for configuration or control.
To achieve this, [Aaron] whipped up a custom PCB which replaces the original cable attached to the NES Advantage. Power is via a small LiPo cell, charged via a TP4056 and paired with a TPS63900 buck-boost converter. An ESP32-WROOM-32E interfaces all the original controls, reading the stick’s CD4021 shift registers to do so. It then either emulates a Switch Pro Controller over Bluetooth Classic, for use with a modern Nintendo Switch, or it acts as a standard Bluetooth Low Energy gamepad for use with PCs, SteamOS, phones, and other compatible hardware. All that and the stick can still work with an original NES if so desired, when placed in the Switch Pro Controller mode. You merely need to plug in an 8BitDo NES Retro Receiver and you’re up and running.
We’ve seen other fun retro controller builds before, too, like this classic Xbox controller modded to work with the Xbox 360. If you’re cooking up similar projects, we’d love to hear about it on the tipsline.
A DIY NES Advantage Controller For The NES Classic
If you were a child of the ’80s, there is a good chance that you had a Nintendo console in your youth, the classic 8-bit NES. And if you were one of those NES owners, it’s therefore probably that the peripheral you lusted after was Nintendo’s arcade-inspired Advantage controller. This replaced the game pad with a full-size arcade joystick and buttons, and has become an expensive and sought-after accessory in the years since.
[Bbtinkerer] has a NES Classic, and having gone through more than one joystick that just wasn’t up to the pressures of intensive gaming, decided to have a go at building one himself. The Advantage was the obvious model to copy, and thanks to the Wii Retropad Adapter project, he was able to do so.
Faithful to the original in its layout, the new Advantage clone features a Turbo mode for rapid fire, though rather than the buttons you’d have had in the ’80s this model features a toggle switch. The joystick mechanism used was a Sanwa JLF, and the buttons were Sanwa OBSF-30s. He’s posted a video showing the finished item being put through its paces.
Continue reading “A DIY NES Advantage Controller For The NES Classic” →
Original NES Advantage Controller Stuffed With Clone NES
famiclone-inside-NES-advantage
Like all good hackers [Osgeld] makes regular appearances at the thrift store to scavenge for raw materials. This summer he was lucky enough to come across a couple of NES clone games. These are controllers that emulate the original Nintendo Entertainment System by connecting to a television using composite video. The mechanics of the controllers were pretty much shot, but he knew he could do something with the boards inside. It was a small gamble at a dollar apiece anyway.
As you can see above, he upgraded a vintage NES Advantage controller by stuffing it full of the emulator hardware. To start he disassembled the arcade-like peripheral and gave everything a thorough cleaning. Since he was going to be soldering onto the PCBs anyway he upgraded the controller by swapping out the original switches for a different set of tactile switches. The large base provided plenty of room for [Osgeld] to fit the emulator (with included ROMs) and now he’s Playing with Power.
The NES Advantage is a very nostalgic controller. Even the Ghostbusters hacked on it!
