Custom Mouse Rocks Neat Thumbstick Design
A mouse is just two buttons, and a two-dimensional motion tracking system, right? Oh, and a scroll wheel. And a third button. And…now you’re realizing that mice can be pretty complicated. [DIY Yarik] proves that in spades with his impressive—and complex—mouse build. The only thing is, you might argue it isn’t really a mouse.
The inspiration for the mouse was simple. [Yarik] wanted something that was comfortable to use. He also wanted a mouse that wouldn’t break so often—apparently, he’s had a lot of reliability issues with mice in recent years. Thus, he went with a custom 3D-printed design with a wrist rest at the base. This allows his hand to naturally rest in a position where he can access multiple buttons and a central thumbstick for pointing. In fact, there’s a secondary scroll control and a rotary dial as well. It’s a pretty juicy control surface. Code is up on GitHub.
The use of a thumbstick is controversial—some might exclaim “this is not a mouse!” To them, I say, “Fine, call it a pointing device.” It’s still cool, and it look like a comfortable way to interface with a computer.
We’ve seen some other neat custom mice over the years, too, like this hilarious force-feedback mouse. Video after the break. Continue reading “Custom Mouse Rocks Neat Thumbstick Design” →
Spherical Keyboard Build Leaves Hacker Well-Rounded
Often times we as hackers don’t know what we’re doing, and we sally forth and do it anyway. Here at Hackaday, we think that’s one of the best ways to go about a new project, and the absolute fastest way to learn a whole lot as you go. Just ask [Aaron Rasmussen] regarding this spherical, standing 5×6 dactyl manuform keyboard build, which you can see in a three-part short video series embedded after the break.
[Aaron] gets right down to it in the first video. He had to get creative right away, slicing up the dactyl manuform model to fit on a tiny print bed. However, there’s plenty of room inside the sphere for all that wiring and a pair of Elite-C microcontrollers running QMK. Be sure to turn on the sound to hear the accompanying voice-overs.
The second video answers our burning question: how exactly does one angle grind a slippery sphere without sacrificing sheen or shine? We love the solution, which involves swaddling the thing in duct tape and foam.
You may be wondering how [Aaron] is gonna use any kind of mouse while standing there at the pedestal keyboard. While there is space for a mouse to balance on top, this question is answered in the third video, where [Aaron] learns the truth behind the iconic ThinkPad nubbin and applies this knowledge to build a force-feedback joystick/trackpoint mouse. Awesome answer, [Aaron]!
Not ready to go full-tilt, sci-fi prop ergo? Dip your toe in the DIY waters with a handy macropad.
Continue reading “Spherical Keyboard Build Leaves Hacker Well-Rounded” →
Unholy Mashup Of SpaceMouse And Sculpt Keyboard Is Rather Well Done
What do you do if you have a pair of input device peripherals for your computer, but they are from different manufacturers and thus not available as a single unit? If you are [Marco van Nieuwenhoven], you combine the two to make a mashup single peripheral.
[Marco]’s two peripherals were a 3Dconnexion SpaceMouse Wireless, and a Microsoft Sculpt Keyboard. His mashup isn’t featured here because it simply is a mashup, after all anyone with a hot glue gun could combine the two, instead he’s created a single peripheral that almost looks as though it could have been manufactured that way. It’s not complexity we’re looking at here, but elegance!
The Sculpt keyboard fortunately has a large palm rest in which the electronics and batteries sit, and he’s carefully measured the footprint of the top half of the SpaceMouse before hand cutting a very neat aperture to take it. The SpaceMouse PCB is attached below the aperture, and the bottom of the palm rest is attached with a little bit of padding to ensure a snug fit. The result: a combined input device to be proud of!
Of course, if this keyboard isn’t special enough for you, how about a typewriter?
A Huge Infra-Red Touch Board
We’re all used to touch pads on our laptops, and to touch screens. It’s an expectation now that a new device with a screen will be touch-enabled.
For very large surfaces though, touch is still something of an expensive luxury. If you’re a hardware hacker, unless you are lucky enough to score an exceptional cast-off, the occasional glimpse of a Microsoft PixelSense or an interactive whiteboard in a well-equipped educational establishment will be the best you’re likely to get.
[Adellar Irankunda] may have the answer for your large touch board needs if you aren’t well-heeled, he’s made one using the interesting approach of surrounding the touch area with an array of infra-red LEDs and photo transistors. By studying the illumination of the phototransistors by different LEDs in the array, he can calculate the position of anything such as a pointing finger that enters the space. It’s an old technique that you might have found on some of the earlier touch screen CRT monitors.
His hardware is built on twelve breadboards mounted in a square, upon which sit 144 LED/phototransistor pairs managed through a pile of 4051 CMOS multiplexers by a brace of Arduino Nanos. If you fancy one yourself he’s provided all the code, though the complex array of breadboards to assemble are probably not for the faint-hearted. You can see it in action in a video we’ve posted below the break.
Continue reading “A Huge Infra-Red Touch Board” →
