Generating G-code With Common Lisp
gcode
Ruin & Wesen are a two person shop creating specialized music gear. As part of their recent MIDI Command development, they got into case manufacturing. They purchased a mini CNC mill to cut the aluminum cases. Unhappy with the software options provide [Wesen] decided to write his own G-code generator. G-code is part of the numerical control used to command CNC machines. He implemented his interpreter using the language he’s most familiar with: Common Lisp (not surprising if you notice the website’s backend). The post covers the design philosophy used and some of the problems that came up. We look forward to future releases since the interpreter can generate milling code using processing.org sketches and cut PCBs directly from Eagle.
You may remember Ruin & Wesen from when they shared their Eagle layout videos.
[Thanks fbz]
Eye-Fi Teardown
eye-fi
[les robots] had a defective Eye-Fi card on his hands and when a replacement was sent, he was told to destroy the original. What better way to ‘destroy’ something than opening the case? The Eye-Fi is an SD card with a builtin WiFi radio so it can upload images while remaining in camera. One version uses Skyhook’s location service to geotag photos. You can see a few photos of the dismantled card on Flickr. The board is manufactured by Wintec. The wireless side is handled by Atheros’ ROCm, the same low power Radio-on-Chip module you would find in a mobile phone. The flash memory comes from Samsung and the antenna is along the back edge, where it has the best chance of getting signal.
Wireless Genesis Controller For PC
wireless_gen
[Jacob] wanted to play some sega games on his PC and felt like the experience just wasn’t complete while using the keyboard for input. He had an old MadCatz controller laying around, which could have probably been connected fairly simply, but he really wanted it to be wireless. A wireless keyboard was sacrificed, and the wireless genesis controller was born. To make it, he disassembled the keyboard to take the controller chip out. After tracing out and soldering switches to the leads, he installed it in his genesis controller.
