Mini MAME Cabinet
[luis] added to the collection of MAME projects we’ve covered with his mini MAME cabinet build. This is his 5th mini cabinet and features a 5″ PlayStation LCD screen, a joystick, four control buttons, player 1 and 2 start buttons, speakers, and a lighted marquee. The controls are interfaced through an I-PAC and the system running the whole thing is a mini-ITX board with an Atom processor and two gigs of RAM. The build log is in Spanish and takes us all the way from a cardboard prototype to the finished particle board cabinet full of high quality artwork.
Continue reading “Mini MAME Cabinet” →
Tap-controlled Metronome
step13_06
[Adam] and his buddy [Matthew] sent in their tap-controlled metronome, or as they prefer, “metronome with an attitude.” Using the piezo speaker you can tap patterns and rhythm into the memory and it will repeat it back to you in loop. The two buttons allow you to speed up or slow down the beat which is indicated by an led array. As per their request, we mention its entirely on a PIC 16F, not an Arduino. Perhaps the most interesting part we found that’s definitely worth checking out was their amazingly detailed build process. Check out a quick video of the metronome in action after the break.
Continue reading “Tap-controlled Metronome” →
80 Gig Drive Inside A Game Boy
[_n3o_] put together a nice external storage mod by fitting a 2.5″ drive into a broken Game Boy. This mod fooled quite a few people because it appears that the device still plays games with the drive stuffed inside of it. Sadly, this is not the case. The reflective backing has been removed from the screen and replaced by a piece of paper with a graphic printed on it. The LED from the hard drive was moved to the battery indicator for the Game Boy for added realism. There is no build log for this project but [_n3o_] did give a short explanation of it in a forum post. You can see two more pictures of the project after the break. Continue reading “80 Gig Drive Inside A Game Boy” →
