[Petar and Sylvain] are teaching this robot to flip pancakes. It starts with some kinesthetic learning; a human operator moves the robot arm to flip a pancake while the robot records the motion. Next, motion tracking is used so that the robot can improve during its learning process. It eventually gets the hang of it, as you can see after the break, but we wonder how this will work with real batter. This is a simulated pancake so the weight and amount at of force necessary to unstick it from the pan is always the same. Still, we loved the robotic pizza maker and if they get this to work it’ll earn a special place in our hearts.
Day: July 28, 2010
WiFi On A Sprint Pixi
[youtube=http://www.youtube.com/watch?v=kpFYoT2lYU0]
The Sprint version of the Palm Pixi doesn’t have a WiFi option but the Verizon version (called the Palm Pixi Plus) does. The hardware is almost the same and [Gitit20] figured out how to do some hardware swapping to add WiFi. The radio board inside the phone is fairly easy to remove. Close inspection of the Sprint radio board shows some solder pads where a WiFi chip would go. The Verizon version has this chip, and moving that radio board into the Sprint phone will enable WiFi. This is strictly a hardware hack as the device identification (IMEA) is paired with the motherboard and not the radio board.
Now we want to see someone source that WiFi chip, solder onto the board, and enable it within the OS so that we don’t need a donor phone to make this work.
[Thanks Juan]
Emulating An Amiga Floppy Drive
[Retromaster’s] Ultimate Floppy Emulator is a wicked display of hardware mastery. It is the culmination of several design stages aimed at replacing an Amiga floppy drive with a modern storage solution. You may be thinking that using an SD card in place of a floppy isn’t all that interesting but this hack does much more. The board, controlled by a PIC32, patches into the Amiga keyboard and monitor. This allows you to bring up an overlay menu for controlling the emulator in order to configure which virtual floppy disk is currently ‘in the drive’. He’s even gone so far as to add a piezo speaker to mimic the sounds the original drive head would make while reading a disk.
[Thanks Gokhan]
Inductive Cellphone Charging Without Voiding Warranty
[Derek Hughes] wanted to use inductive charging on his cellphone without voiding the warranty. He picked up a Pixi charging backplate meant for a Palm Pre and scavenged the coil and regulator circuitry from it. To make the electrical connection with his HTC HD2 he removed the mini-USB plug from a charging cable and connected it with 30 gauge wire. The whole package will fit beneath the back plate for use with a Touchstone charger (as we’ve seen with the HTC Evo) but there was one problem. The metal backplate from the HD2 interferes with the inductive charging. For now he’s using tape to hold everything together while searching for a plastic case replacement.
He walks you through the hack in the video after the break. We’re usually not worried about voiding warranties, but a phone like this takes a lot of abuse and having warranty protection or even a service agreement isn’t a bad idea. Continue reading “Inductive Cellphone Charging Without Voiding Warranty”
Extra Extra: Now Legal To Jailbreak IPhone
For those living under a rock, the latest ‘greatest’ news to hit hacking front page is the the Copyright Office granting Six Exemptions Regarding the Circumvention of Access-Control Technologies. Of the six the one of the two regarding iPhones is as follows,
“(2) Computer programs that enable wireless telephone handsets to execute software applications, where circumvention is accomplished for the sole purpose of enabling interoperability of such applications, when they have been lawfully obtained, with computer programs on the telephone handset.”
Which (along with section 3) really just means that you can unlock and crack cellphones and companies can no longer fine you $2,500. Not that many ever have but the threat was there. Apple however, can and still will void your warranty if you jailbreak.
The 4 other areas not involving phones are the ability to circumvent DVDs for portions of video, video games in order to better the security of said game, computer programs that require dongles but dongles are no longer available, and literary works that prevent read-aloud or rendering to a specialized format.
One tidbit I keep hearing about in these exemptions is the ability to now break DRM on music, as much as I wish this were true, I can’t seem to find any sources on it, sorry pirates.
Regardless, now that the world is one step closer to an open framework, whats changed? For me, I’ve been jailbroken for years so sadly nothing. If you agree with the ruling, disagree, or just want to tell about your now legal jailbreaking joys, please leave a comment.
Additional Sources: FOXNews and CNNMoney thanks to [Voyagerfan99], [Ryan Knight], and [Steve S.] respectively.
[Image credit: Fr3d.org]
