BTTF Alarm Clock
Back To The Future Alarm Clock Is As Real As It Gets
While real time-travel is obviously not happening anytime soon, with this Back to the Future themed alarm clock, you can go to the future in seven hour eight hour increments by going to sleep. Great Scott!
[CrossleyAcoustics] spent the past few months designing and building this movie-prop worthy alarm clock, and it certainly shows. After designing everything on breadboards, he had custom PCBs made, he modeled the whole thing in Sketchup (first time he’s used it!) and even tried his hand at the sheet metal fabrication after shops quoted him thousands for what he wanted.
The coolest part of the build is that [CrossleyAcoustics] had some detailed drawings that he had made himself… when he was 8 years old. Talk about a plan coming together!
Continue reading “Back To The Future Alarm Clock Is As Real As It Gets”
Swimming Pool Dance Floor Enlightened With Leds
In a well documented blog entry, [Loren Bufanu] presents a project that lit up a glass dance floor covering a swimming pool with RGB strips. We mentioned a video of his project in a Hackaday links but didn’t have any background information. Now we do.
boards in boxThe project took around 450 meters of RGB strips controlled by two Rainbowduinos and driven by sixty-four power Mosfets, sixty-four bipolar transistors, and a few other components. Producing white light from the LEDs draws 8 amps from the power supply.
The Rainbowduino is an ATmega328 Arduino compatible board with two MY9221 controllers. Each  controller handles 12 channels of Adaptive Pulse Density Modulation. In other words, it makes the LEDs flash nicely. [Loren] used the Rainbowduino instead of some alternatives because multiple R’duinos can coordinate their activities over I2C.
The software part of the project did not work as well as the hardware. The light patterns were supposed to follow the music being played. A PC software package intended to drive the R’duinos produced just a muddy mess. Some kludges, including screen captures (!), driven by a batch file tamed the unruliness.
It’s been awhile, but a similar disco dance floor, built by [Chris Williamson] but not over a pool, previously caught our attention. [Chris] is a principle in Terror Tech that recently got a mention on Sparkfun.
The video after the break fortunately does not make a big splash, but is still electrifying.
Continue reading “Swimming Pool Dance Floor Enlightened With Leds”
3D Printed Turbofan Features Reverse Thrust
[Harcoreta] has created a 3D printed model of the GE GEnx-1B Turbofan. This is the engine that powers Boeing’s 787 dreamliner. What sets this model apart is that it has a complete working reverse thrust system. A real jet engine would be asking a bit much of 3D printed ABS plastic. This model is more of an Electric Ducted Fan (EDF). An NTM 1400kv 35mm brushless motor hides in the core, cooled by a small impeller.
jet-nakedWhat sets this apart from other jet models is the working reverse thrust system. [Harcoreta] painstakingly modeled the cascade reverse thrust setup on the 787/GEnx-1B combo. He then engineered a way to make it actually work using radio controlled plane components. Two servos drive threaded rods. The rods move the rear engine cowling, exposing the reverse thrust ducts. The servos also drive a complex series of linkages. These linkages actuate cascade vanes which close off the fan exhaust. The air driven by the fan has nowhere to go but out the reverse thrust ducts. [Harcoreta’s] videos do a much better job of explaining how all the parts work together.
The model was printed on an Reprap Prusa I3 at 0.1mm layer height. [Harcoreta] smoothed his prints using acrylic thinner, similar to the acetone vapor method. Unfortunately, [Harcoreta] has only released a few of the design files on rcgroups, but we’re hoping he will drop the whole model. We can’t wait to see a model dreamliner landing just like the big boys!
Continue reading “3D Printed Turbofan Features Reverse Thrust”
Stuffing Macs Into FPGAs
A few years ago, [Steve] of Big Mess ‘O Wires fame stuffed one of the first Macintosh computers into an FPGA. While the project worked and was able to run System 6 on a virtual CPU, there were a few problems: it wasn’t exactly stable, and there was no support for a keyboard, sound, SCSI, or serial ports.
Now, there’s a new tiny FPGA board around, and this one is perfectly designed to fit the original Macintosh on it. It’s much more stable, and there is a floppy disk emulator on the horizon, just so you won’t have to deal with all those 400k 3.5″ disks anymore.
[Steve]’s brand new Mac Plus is based on the MiST board, an FPGA board that was originally designed to emulate the first Amigas and the Atari SE on an FPGA and a separate ARM CPU. There’s already been a lot of classic computers ported to the MiST, and the classic all-in-one Macs are the last project that’s left.
In the video below, you can see the MiST board running the classic System 6 at SVGA resolution. That means MacPaint and Shufflepuck in one compact board using modern hardware.
Continue reading “Stuffing Macs Into FPGAs”
Radio Jamming Rifle Claimed To Disable Drones
[Battelle], an Ohio-based non-profit R&D firm has just unveiled a device they call the DroneDefender — a long-range anti-drone defense weapon. It almost sounds like they’ve brought the fictional drone hunter’s RF cannon to life. But does it really work?
According to the site, it uses radio frequency disruption to blast unwanted drones out of the sky. Cool concept, but does it actually work? Unlike the hackable MAVLink protocol used by Parrot AR, ArduPilot and a handful of other consumer drones, this weapon uses brute radio signal force to disable any(?) consumer drone.
There’s a video after the break demonstrating a simulated use of the technology, which leaves us a bit confused. They show the drone slowly landing all nicely after being “guided” down by the rifle. If the system is jamming both GPS and the 2.4 GHz control link, the behavior will all depend on the software loaded on the drone. Some will go to a fail-safe mode, which is low throttle or motor power off, assuming the pilot has set fail-safe. Others may attempt to loiter on IMU sensors only.
Continue reading “Radio Jamming Rifle Claimed To Disable Drones”
Low-Cost, Arduino-Compatible Drawing Robot
Bringing women into technical education at times seems to be an insurmountable challenge. As a counter, a small drawing robot created by [MakersBox] might help. The robot was used in a ChickTech workshop for teen girls.
640px-Turtle_draw
“Turtle draw” by Valiant Technology Ltd..
The goals for the robot were to have an easy to build, easy to program robot that did something interesting, and was also low-cost so the workshop participants could take it home and continue to learn. These requirements led [MakersBox] to the Adafruit Pro Trinket 3V, stepper motors for accuracy, and a 3d printed chassis to allow for customization.
Another version of the Arduino should work without any problems and even possibly a Raspberry Pi, suggests [MakersBox]. With the latter’s more diverse programming environment opening up a lot of possibilities
Drawing robots like this for education are not new. [Seymour Papert] created one of the first turtle robots, seen at the left, in the 1980s. He even created the Logo programming language and adapted it for use with the turtle. An interesting similarity between [MakersBox’s] and the original turtle is the drawing pen is in the center of both.
Hat tip to our friends at Adafruit.
A rose, is a rose, is a rose, even if drawn by a robot, after the break.
Continue reading “Low-Cost, Arduino-Compatible Drawing Robot”
An Internet Connected Earth
It shouldn’t come as much of a surprise that more than half of the world’s population doesn’t have an Internet connection. It’s tricky to get an exact figure on this, however the number of people without connection is commonly agreed to be somewhere around 2/3rds of the population of the planet. There are some heavy hitters working on this problem with some pretty interesting solutions.
OneWeb is an outfit with [Richard Branson] as the front-man who plan to launch low orbit satellites to communicate with ground terminals. The ground terminals would rebroadcast the communication signals from the satellites resulting in 2G, 3G, LTE, and WiFi signals for those near a ground terminal.
SpaceX is throwing its hat in the ring with a little helpful funding from Google and Fidelity to the tune of $1 Billion.
Perhaps the most surprising is [Zuckerberg’s] solar-powered internet laser beaming drones. The idea is that these laser birds will circle over an Internet dead-zone like buzzard over a dying buffalo (reaching?) and provide connectivity to those below. The solar drones will fly at an altitude of 20km which is a pretty good ways up there, and they are believed to be able to stay in flight for months at a time. There’s a Facebook PhD explaining this in a video after the break, thanks Dr. Facebook.
Continue reading “An Internet Connected Earth”
