Tiny Function Generator On The ATtiny85, Complete With OLED
It’s easy to have a soft spot for “mini” yet perfectly functional versions of electronic workbench tools, like [David Johnson-Davies]’s Tiny Function Generator which uses an ATtiny85 to generate different waveforms at up to 5 kHz. It’s complete with a small OLED display to show the waveform and frequency selected. One of the reasons projects like this are great is not only because they tend to show off some software, but because they are great examples of the kind of fantastic possibilities that are open to anyone who wants to develop an idea. For example, it wasn’t all that long ago that OLEDs were exotic beasts. Today, they’re available off the shelf with simple interfaces and sample code.
The Tiny Function Generator uses a method called DDS (Direct Digital Synthesis) on an ATtiny85 microcontroller, which [David] wrote up in an earlier post of his about waveform generation on an ATtiny85. With a few extra components like a rotary encoder and OLED display, the Tiny Function Generator fits on a small breadboard. He goes into detail regarding the waveform generation as well as making big text on the small OLED and reading the rotary encoder reliably. His schematic and source code are both available from his site.
Small but functional microcontroller-based electronic equipment are nifty projects, and other examples include the xprotolab and the AVR-based Transistor Tester (which as a project has evolved into a general purpose part identifier.)
4 thoughts on “Tiny Function Generator On The ATtiny85, Complete With OLED
  1. i had one question, which seems to be answered on technoblogy: how D->A? and the answer is PWM with a 64MHz counter. several handy sources of high frequency noise, if that’s what you wanted.
    of course if it’s fundamentally an audio project then that hardly matters.
  2. I read the title as ‘Tiny Fusion Generator on the ATTINY85. Might be a good title when fusion generation is miniaturized and simplified enough for us tinkerers to dabble with :)
Leave a Reply to MarkCancel reply
