If you were a youth in the 90s, odds are good that you were a part of the virtual pet fad and had your very own beeping Tamagotchi to take care of, much to the chagrin of your parents. Without the appropriate amout of attention each day, the pets could become sick or die, and the only way to prevent this was to sneak the toy into class and hope it didn’t make too much noise. A more responsible solution to this problem would have been to build something to take care of your virtual pet for you.
An art installation in Moscow is using an Arduino to take care of five Tamagotchis simultaneously in a virtal farm of sorts. The system is directly wired to all five toys to simulate button presses, and behaves ideally to make sure all the digital animals are properly cared for. Although no source code is provided, it seems to have some sort of machine learning capability in order to best care for all five pets at the same time. The system also prints out the statuses on a thermal printer, so you can check up on the history of all of the animals.
The popularity of these toys leads to a lot of in-depth investigation of what really goes on inside them, and a lot of other modifications to the original units and to the software. You can get a complete ROM dump of one, build a giant one, or even take care of an infinite number of them. Who would have thought a passing fad would have so much hackability?
No it needs a mechanical arm to activate the switches – haveing it hard wired is a cop out…
From an artistic perspective it kind of makes sense. From the general aesthetic, it seems like it’s meant to be as matrix-like as possible, maybe even a social commentary about the negative aspects of how tech is being used, and the direct wires convey the idea of cold efficiency pretty well.
I general I’m a fan of using the newest and latest technology. I don’t really use record players, paper journals, or film cameras.
But when you combine it with minimalist aesthetics, greed, and a general lack of consideration of the actual effects of what you’re doing on the living people that interact with it…. You get things like this. Undecorated glass towers that get ridiculously hot without massive amounts of A/C, devices that do exactly one thing and are very difficult to modify or repair or do anything except toss in the bin, and lots of internet content that doesn’t really produce joy or add to knowledge.
A mechanical arm would have looked way cooler though, and that’s probably how I would have done it.
come back one you’ve done it.
pictures or it did (burp) n’t happen
The visual presentation of the project is excellent. Well done.
The irresponsible 90’s self, the act of irresponsibility to waste time with one… to.PAY for one, a waste in and of itself… self defining. There should be a HaD Hell for this sort of thing. A level above or below Dante’s HaD Hell, I cannot judge. Give me a computer, (nevermind – I’ll build it,) and I’ll strip solitare. If it’s useful, like flight simulator, ok. Don’t tell me those taught responsibility.
