Vertical Mill Completes Scrapyard Lathe Build
One thing’s for sure: after seeing [Roland Van Roy] build a vertical mill from industrial scrap, we’ve got to find a better quality industrial scrapyard to hang around.
The story of this build started, as many good shop stories do, at the lathe, which in this case was also a scrapyard build that we somehow managed to miss when it first posted. This lathe is decidedly different from the common “Gingery method” we’ve seen a few times, which relies on aluminum castings. Instead, [Roland] built his machine from plate stock, linear slides, and various cast-off bits of industrial machines.
To make his lathe yet more useful, [Roland] undertook this build, which consists of a gantry mounted over the bed of the lathe. The carriage translates left and right along the bed while the spindle, whose axis lines up perfectly with the center axis of the lathe, moves up and down. [Roland] added a platform and a clever vise to the lathe carriage; the lathe tool post and the tailstock are removed to make room for these mods, but can be added back quickly when needed. Digital calipers stand in for digital read-outs (DROs), with custom software running on a Picaxe and a homebrew controller taking care of spindle speed control.
[Roland] reports that the machine, weighing in at about 100 kg, exhibits a fair amount of vibration, which limits him to lighter cuts and softer materials. But it’s still an impressive build, and what really grabbed us was the wealth of tips and tricks we picked up. [Roland] used a ton of interesting methods to make sure everything stayed neat and square, such as the special jig he built for drilling holes in the T-slot extrusions to the use of cyanoacrylate glue for temporary fixturing.
12 thoughts on “Vertical Mill Completes Scrapyard Lathe Build
    1. Very cool and quite impressive. It makes me want to finish my own Mini Mill DRO project!
      If those projects haven’t been featured on Hackaday, they certainly should be.
  1. Resourceful design for lighter materials… though the stickiness of some softer materials makes me cringe.
    Great seeing some steel or at least iron in the comment threads.
    I worry about some of the designs being aluminum extrusion when decent machine cast salvage can be found reasonably priced that can have the voids filled in too once cutting and fabrication is done if needed/wanted.
    There are the concrete and granite resin methods too Hackaday’s demonstrated.
    https://hackaday.com/?s=epoxy+granite
    https://hackaday.com/?s=concrete+granite
    https://hackaday.com/?s=concrete+mill+lathe
    Thinking the cast iron/steel blocks or even I guess large enough heads can be waterjet cut, ground or even machined, drilled and tapped, and used for a stiffer more solid design.
    I’m well away of space and size concerns and wonder at times why I’ve turned down way cost effective and even free CMM/CMS granite surface plates. Understandable. Just received a few days ago, a reported 0.001″ spec straight edge that I still need to verify since I DON’T have a 24″ surface plate or another to compared to. My largest surface plate is 18″ since man, I have the room and that’s just before where the shipping spike goes significantly more.
    Might be a little pricey for many, though I just picked up a plate from a autonomous robot LiDAR system and they have more left. I almost invested in a second for a welding table. I haven’t cleaned off yet to determine how true. Way better price than I can find anywhere left.
    https://www.ebay.com/itm/27-1-2-x-39-1-4-Plate-Steel-3-4-Thick-Layout-Setup-Workholding-Jig/363032368202
    They have a nice size angle plate I’ve been looking at too.
Leave a Reply to thenCancel reply
