Backup Tapes Come Back To The Homelab
It’s one of the great mysteries of computing, how somehow in the Year Of OLlama 2026, tape remains the god of cheap storage. A while back [Ben Pettis] recounted his experience setting up an LTO-5 tape drive in his homelab, an experience which only becomes more relevant as hard drive prices stay high.
LTO-5 is already well out of date in the professional world, after all– a new server install would be debating the merits of LTO-9 versus LTO-10, but for the homelab it’s a matter of what’s affordable on the used market with decently-sized cartridges. If you can live with 1.5 TB of uncompressed data on a roughly palm-sized Linear Tape, Open cartridge then LTO-5 could be good enough. Yes, the tapes are advertized as 3TB, but that’s assuming a 2:1 compression ratio on the data, which you’re not likely to get on the photos and video that make up much of a data horder’s storage. That’s one thing [Ben] was quick to clear up for us. He also detailed his adventures with the cheaper-to-buy fiber channel model of drive.
The label would have you believe this box stores 30 TB.
Tape drives usually come with an SAS or fiber channel interface– fiber channel being, you guessed it, an optical solution unlike the SCSI-like SAS connection you may be familiar with for block storage devices. With a PCIe adapter it’s not hard to set up, provided you get the cables the right way around! That’s another detail we’re glad [Ben] shared so we can find it again if we have the same problem: with no switch in the circuit, you need a crossover cable to bring TX to RX. Which is obvious in retrospect, but obscure to those of us just learning about the standard.
The advantage, as [Ben] makes clear and everyone has always known is simply price. As of this writing, diskprices.com has 16$/TB as the lowest cost, while [Ben] was able to pick up lightly-used tapes on eBay for only 2$/TB. If you have a lot of data, those savings amortize the drive costs relatively quickly, since a used drive like [Ben]’s can be had for a few hundred bucks.
Is it the ultimate solution for our data storage woes? That depends on your needs, but perhaps not considering we get as many tips on storing data on reel-to-reel as we do on LTO. We even saw a tape-loading robot repurposed to serve bar one time.
A Free Cloud AI
If you would like an AI “personal agent” but don’t want your data on some opaque cloud computer, there’s a new option that appears to be somewhat nicer: [rociiu] has talorys, an AI agent that runs in your Cloudflare account. True, it is still on a cloud computer, but it is your account on a cloud computer. It is designed so you can use it on Cloudflare’s free account with reasonable limits, and the code running is all on GitHub, so you can — if you are so inclined — look to see what it is doing. The data, too, is all in your cloud instance.
This seems like a reasonable compromise. Cloudflare provides the hosting, and the software in your virtual computer does all the work. At least, that’s how it is promoted. Honestly, we haven’t combed over the code, but the assertion is “Free-tier friendly… no telemetry.”
We are fairly sure they are using Cloudflare’s AI engines, too, so it would be interesting to see how much of your data they could, in theory, harvest in transit. Of course, your data is still in the cloud, so if you are really worried about privacy, this might not be for you. But since everything is in your account and open, you can at least have more control over what’s there. For example, you can easily download or delete your data. You can even see exactly what prompts it uses.
Continue reading “A Free Cloud AI” →
