Sometimes the best inspiration is limitation. The 555 timer does “one thing” — compares a voltage to a couple thresholds and outputs a signal accordingly. It’s two comparators, a voltage ladder, and a flip-flop. And yet, it’s the most sold single chip of all time, celebrating its 50th birthday this year! So when Hackaday runs a 555 Timer Contest, hackers of all stripes come out with their best work to show their love for the Little DIP That Could.
The Winners
Far and away the favorite entry was the Giant 555 Timer by [Rudraksha Vegad]. Every one of our judges rated it in the top five, and it took top honors twice. On its face, this is a simple “giant 555 in a box” build, but have a look under the hood. Each sub-module that makes up the 555 — comparators, flip-flop, and amplifier — are made from salvaged discrete parts in actual breadboard fashion, soldered to brass nails hammered into wood. As an end product, it’s a nice piece of woodworking, but as a process of creation, it’s a masterwork in understanding the 555 at its deepest level. We should all make one!
The Menorah555 is a simple design with some very nice tricks up its sleeve. Perhaps the cutest of which is pulling the central candle out and lighting the others with it — a trick that involves a supercapacitor and reed switches. Each of the candle lighting circuits, however, use a 555 timer both for its intended purpose of providing a timed power-on reset pulse, and another 555 is used as a simple flip-flop. It’s a slick design, and a great user interaction.
The Cyclotone Mechanical Punk Console Sequencer is a rotating tower of circuit sculpture and noisemakers. This one looks great, is amazingly well documented in the video series, and uses a billion clever little tricks along the way. The 555’s role? Each of the four levels is the classic Atari Punk Console circuit.
All three of these projects win a $150 shopping spree at Digi-Key. That’s a lot of timers!
Continue reading “Congratulations Winners Of The 555 Timer Contest!”
