Scrapyard Vacuum Dehydrator Sucks The Water From Hydraulic Oil
Anyone who has ever had the misfortune of a blown head gasket knows that the old saying “oil and water don’t mix” is only partially true. When what’s coming out of the drain plug looks like a mocha latte, you know you’re about to have a very bad day.
[SpankRanch Garage] recently found himself in such a situation, and the result was this clever vacuum dehydrator, which he used to clean a huge amount of contaminated hydraulic fluid from some heavy equipment. The machine is made from a retired gas cylinder welded to a steel frame with the neck pointing down. He added a fill port to the bottom (now top) of the tank; as an aside, we had no idea the steel on those tanks was so thick. The side of the tank was drilled and threaded for things like pressure and temperature gauges as well as sight glasses to monitor the process and most importantly, a fitting for a vacuum pump. Some valves and a filter were added to the outlet, and a band heater was wrapped around the tank.
To process the contaminated oil, [Spank] glugged a bucket of forbidden milkshake into the chamber and pulled a vacuum. The low pressure lets the relatively gentle heat boil off the water without cooking the oil too badly. It took him a couple of hours to treat a 10-gallon batch, but the results were pretty stark. The treated oil looked far better than the starting material, and while it still may have some water in it, it’s probably just fine for excavator use now. The downside is that the vacuum pump oil gets contaminated with water vapor, but that’s far easier and cheaper to replace that a couple hundred gallons of hydraulic oil.
Never doubt the hacking abilities of farmers. Getting things done with what’s on hand is a big part of farm life, be it building a mower from scrap or tapping the power of the wind.
Continue reading “Scrapyard Vacuum Dehydrator Sucks The Water From Hydraulic Oil” →
Nebraskan Farmers Were Using Wind Turbines Before Environmentalism Was Invented
To a casual observer of public discourse here in 2024 it seem extremely odd that the issue of replacing coal fired power stations with wind turbines is a matter of controversy, whether in America or Europe it’s an issue which causes some sparks to fly. The Atlantic has a recent article with a set of pictures from a gentler time in which the industrious nature of Nebraskan farmers in the 1890s receives praise as they create a wide variety of home-made wind turbines.
Farmers have always been the best hardware hackers, using what they have at hand to solve their problems and create the things they need. Perhaps out image of agricultural wind power is one of commercially produced wind pumps, but these are the generation of home-made devices which preceded that. Some of them look conventional to modern eyes, but others such as the horizontal “Jumbo” turbines have little equivalent today.
It’s easy to forget with so many energy sources at our disposal, that in the past the locality affected the choice of motive power. The Netherlands doesn’t have windmills because they are pretty, but because hundreds of years ago they lacked handy coal mines or convenient heads of water. Similarly out in the Nebraskan prairies they had plenty of wind, and never the folk to pass up on an opportunity, they made the best of it. And we’re very glad over a century later, that someone took the time to record their work.
If you’re hungry for more old-style wind power, we’ve got you covered, meanwhile 19th century America was no stranger to clever ways to use power.
Thanks [Hugh Brown] for the tip.
This Car Has Wooden Performance
If you were to take a look at the car parked closest to where you are sitting, there’s an overwhelming probability that its main structural parts are made of steel. A few might be aluminium and fewer still composite materials, but by and large that’s it for automotive structures. This hasn’t stopped the inventive Russians at [Garage 54] from experimenting though, and in their latest they’ve made a car with a chassis made of wood. Not carefully sawn and assembled wooden structural components, oh no. These are wooden tree trunks and branches.
Of course it’s an opportunity for them to run wild on their very successful schtick of the crazy Eastern European YouTuber, but behind that it’s entertaining to watch how they adapt a drive train — taken we’re guessing from the FIAT 124-derived Zhiguli, or Lada as most of us would know it — to such an unconventional chassis. A lot of wire binding is used, and even then the car has a lot of the flexible about it. We’re not so sure about the differential without oil or indeed the front suspension that appears to be developing a lean, but they do manage to take it out of the forest and onto the road.
Are unconventional and definitely-not-road-legal motors your thing? Here’s another, courtesy of some Dutch lads.
Continue reading “This Car Has Wooden Performance” →
A Ride-On Picnic Table For Those Idylic Summer Evenings
For most outsiders the Netherlands is a country of picturesque cities, windmills, tulips, and maybe those famous coffee shops. Head away from the coast though and you enter the country’s rural hinterland, farming country with lush green fields, dairy cattle, and farm lads doing what they do best, which is hacking old machinery to do crazy things under those wide skies. [Plodno] are based on a farm somewhere in the eastern Netherlands, and the latest of these lads’ creations is a motorised picnic table (Dutch language, you’ll need YouTube translated subtitles).
This is farm hacking at its best, with a scrap FIAT hatchback donating its running gear to a welded tubular frame, with a chain drive to a small single-cylinder engine. There’s no suspension save for the air in the tyres, the steering column is vertical, and the brake is a single inboard disk on the rear axle. Perhaps it’s fortunate that the intended beating heart, a Kawasaki motorycle engine, was misfiring, as it would have been truly lethal with that much power. We’re not too convinced at the legality of taking such a contraption on the public road in the Netherlands, but they seem to get away with it. Take a look at the build in the video below the break.
Here at Hackaday we like a good hacky farm build, even though sometimes they’re not so well-assembled.
Continue reading “A Ride-On Picnic Table For Those Idylic Summer Evenings” →
