EEG graph with activity sections highlighted, one part highlighted as "F" and other as "6"
DREEMWORK Lets You Code Morse From Inside Your Dream
Lucid dreaming fascinates hackers. Every few years for over a decade now, we’ve seen a serious project dedicated to studying or taking advantage of this phenomenon, and the interest in this topic hasn’t faded still. [Michael] has contacted us to tell about a small and unconventional breakthrough that a few lucid dream hackers have accomplished — communicating in Morse code from their dream using eye movements.
These hackers are using Dreem 2 and 3 headbands, which include clinical-grade polysomnography features like EEG measurements, which is instrumental for decoding eye movements. [Michael] tells us that one of the participants, [Sebastiii], was able to transfer the letter F by looking twice to the left, then right and left again – ..-. in Morse. With an off-the-shelf headband, this information transmission method is quite accessible to anyone willing to learn Morse, and [Michael] himself is now working on an automated decoding solution. We might forget what happens in our dreams fairly quickly, but this unexpected side channel could be a good counter.
[Michael] has tipped us off to many of the projects we’ve covered, and himself has quite a history in the field. His own research into using Morse to communicate out of lucid dreams dates back as far as 2012. If your ham exam preparations have you dream in Morse, perhaps this is the perfect project to join. A lot of projects we’ve seen focus on gaining enough awareness to achieve lucidity first, like the variety of lucid dream-invoking masks we’ve covered over the years. This part being thoroughly explored, it makes sense that communication is the next frontier to be tackled.
Building A Mask To Induce Lucid Dreaming
While dreams are generally thought of as the unconscious wanderings of the mind, that’s not the full story. Lucid dreams are ones in which the individual is conscious or semi-conscious in the dream state, and may be able to control the dream environment. Over the years, various devices have been used to generate these dream states more reliably. [Ben] decided to have a go at building his own, inspired by designs from the 1990s.
To induce lucid dreaming, the aim is to first detect that the mask wearer is in REM sleep. This is commonly done with an infrared eye tracker, which detects the rapid twitching of the eye. [Ben] used the onboard IR proximity sensor on the Adafruit Circuit Playground Express to pull this off. The accelerometer hardware was then used to detect if the wearer was still, indicating they are indeed fully asleep. Once the user is in the correct state, the mask then flashes LEDs which are intended to be visible to the wearer while dreaming. This allows them to realise they are dreaming, and thus enter a conscious, lucid state.
[Ben] doesn’t report the success rate at using the mask, but we’d love to know more about how well the mask works. We’ve seen others do similar work before, and even a recent Hackaday Prize entry. Video after the break.
Continue reading “Building A Mask To Induce Lucid Dreaming” →
Project Lucidity Wants YOU!
dreamingz
Do you lucid dream? Do you want to? [Dinesh Seemakurty] has just started something called Project Lucidity, which is the first(?) open source, developer friendly, fully featured, lucid dreaming sleep mask. And he’s looking for hackers to help!
We’ve covered lots of projects on lucid dreaming before, like making your own homemade lucid dreaming goggles, or modifying a commercial EEG headset for lucid dreaming. We also can’t forget the LucidScribe project either, the one that seeks to communicate from within dream state!
Anyway, what’s different about Project Lucidity? Well, first of all, it’s open source. Second of all, it’s based on an ATMEGA328P, meaning it’s fully compatible with the Arduino IDE. It looks like a great start, and [Dinesh] is planning on taking everything open source very soon — but before then he wants you to try it out!
If this sounds like a project you want to get behind and help develop, check out his site and sign up. Or ask away in the comments section!
Electrooculograph (EOG) From A Video Stream
[Michael] from Lucidcode is at it again, this time with an Android app called Halovision.
In case you don’t remember, this is the guy who has been working on the Lucid Scribe Project, with the end goal of communicating from inside your dreams! Here’s the basic gist of it. If we can use a sensor to detect REM (rapid eye movement) or body movement during sleep, we can tell if we’re dreaming — then it’s just a matter of using an audible cue to inform the sleeper of the dream, so they can take control and become lucid.
The first way they did this was by using commercial EEG headsets to detect REM. We covered a hack on modifying one so it would be more comfortable to wear at night, but what is really exciting is [Michael’s] new app, Halovision — No EEG required
It’s an Android app that uses the camera to detect movement during sleep, and it is only the first plugin planned for Lucid Scribe. The algorithm is still in its experimental stages, but it is at least somewhat functional at this time. They note it’ll only work for day-time naps or with a bright night light, but this could be easily solved with an IR webcam and a few IR LEDs.
It will be interesting to see where this all goes, has anyone else been following or participating in Lucid Scribe?
Lucid Dreaming Mask Marries Economy With Comfort
Here’s an effort to make a cheap lucid dreaming mask that is also comfortable. The idea is in response to the goggles we saw in April (which would not be too comfortable to sleep in) and the wildly successful Remee (which has an $80 target price).
The mask itself is sewn from a child’s fleece blanket. Inside is a piece of foam cut from some recreation mat. You know, those squares made for a play area that connect together like a jigsaw puzzle. You may have already spotted the Arduino in the image above, but the project is designed to run from an AVR chip embedded in the foam. The design only uses three LEDs, which may or may not work for you — we’d guess it depends on how they line up with your eyes. The video after the break does a great job of illustrating each point in the construction.
If you’re looking for something less soothing and more recreational you could always try out these trippy goggles.
Continue reading “Lucid Dreaming Mask Marries Economy With Comfort” →
Do Anything With The Help Of Lucid Dreaming Goggles
In the world of your dreams, you can build an entire world, an entire universe, an entire society governed by your every whim. While lucid dreaming you are a god in your own mind, free to create or destroy at will. You can train yourself to recognize when you are dreaming, but sometimes a little technological help can speed you towards the path of becoming an old testament god. [Will] over at revolt lab built a set of lucid dreaming goggles so he could take control of his own dreams.
To induce a lucid dream, [Will] took a pair of safety goggles and attached red LEDs to shine into his closed eyes. A simple circuit was constructed out of an ATtiny85 that blinks the LEDs two hours after being turned on. The idea is these LEDs will be noticed by the user during REM sleep and they will realize they’re still sleeping. After that, it’s basically Inception.
It is possible to induce lucid dreaming through psychological and not technological hacks; just asking yourself, ‘am I dreaming’ throughout the day may be enough to make a holodeck in your mind while you’re sleeping. You can check out a video of [Will] wearing his goggles after the break.
Continue reading “Do Anything With The Help Of Lucid Dreaming Goggles” →
