South Korea Brought High-Rise Fire Escape Solutions To The Masses
When a fire breaks out in a high-rise building, conventional wisdom is that stairwells are the only way out. Lifts are verboten in such scenarios, while sheer height typically prevents any other viable route of egress from tall modern buildings. If the stairs are impassable, or you can’t reach them, you’re in dire peril.
In South Korea, though, there’s another option for escape. The answer involves strapping on a harness and descending down ropes hanging off the side of the building, just like in an action movie. It might sound terrifying, but these descending lifeline devices have become a common part of fire safety infrastructure across the country.
Continue reading “South Korea Brought High-Rise Fire Escape Solutions To The Masses”
South Korea Successfully Sends Satellites To Orbit
South Korea’s KARI ( Korea Aerospace Research Institute ) successfully put a commercial satellite into orbit Thursday, achieving another milestone in their domestic space program. The Nuri rocket (aka KLSV-2) left the Naro Space Center launch pad on the southern coast of the peninsula at 18:24 KST, after a communications glitch in the pad’s helium tank facility caused a one-day slip. The primary payload was the 180 kg refrigerator-sized Earth observation satellite NEXTSat-2. It uses synthetic aperture radar (SAR) and also has instruments to observe neutrons in near-Earth orbit due to the impact of solar activity on cosmic radiation. In addition, seven CubeSats were successfully deployed:
  • Justek JLC-101-V1.2, to verify satellite orbital control system
  • Lumir, measuring cosmic radiation and testing rad-hardened microprocessor design
  • Cairo Space, weather observation and space debris technology demonstration
  • KASI-SAT (Korea Astronomy and Space Science Institute) SNIPE, actually four nano-sats which will achieve a 500 km – 600 km polar orbit and fly in formation to measure plasma variations.
It seems that SNIPE-C, Justek, and Lumir are having communication troubles and may be lost. Ground controllers are still searching. This launch comes almost one year after the previous launch of a dummy satellite in June, which we wrote about last year.
Continue reading “South Korea Successfully Sends Satellites To Orbit”
South Korea’s KSLV-2 Rocket Delivers Payloads To Orbit
South Korea’s domestically developed KSLV-2 “Nuri” rocket successfully placed six payloads into low Earth orbit Tuesday, after lifting off from from Naro Space Center at 4 PM KST. This follows an earlier attempt in October which failed to reach orbit after the booster’s third stage engine shutdown prematurely. The flight followed an initial trajectory over the East China Sea, after which the upper stage steered out towards the Philippine Sea, finally placing the payload in the desired orbital inclination of 98 degrees. This less-than-ideal path wasted energy, but ensured that the first and second stages fell into the ocean and not onto people. Success was confirmed shortly after launch as the vehicle passed over South Korea’s King Sejong Station in Antarctica.
The payload on this test flight was primarily a mass simulator of 1.3 metric tons, but a small Performance Verification Satellite (PVSAT) was included, for a grand total of 1.5 metric tons. The PVSAT itself monitors vehicle performance, but also serves as a carrier for four CubeSats. These were developed by engineering teams at various local universities and will be deployed in the coming days.
If you’re inclined to track these, the launch has been given COSPAR ID 2022-065 and the first three objects (third stage, dummy mass, and PVSAT) have been assigned the NORAD catalog numbers 52894, 52895, and 52896. It’s too early to tell which is which at this point, but as more data about their respective orbits are collected, it should be possible to tell them apart. The next four catalog numbers, 52897 – 52900, have been reserved for the CubeSats once they are released.
With this launch, South Korea has become the 10th nation to put a payload into space using its own domestic technology, and the 7th to loft a payload of more than one ton to orbit — joining the ranks of the United States, Russia, Japan, China, France, and India.
Continue reading “South Korea’s KSLV-2 Rocket Delivers Payloads To Orbit”
Illuminating Origami Is Just Around The Corner
Pop-up greeting cards are about to get a whole lot more interesting. Researchers at Seoul National University in Korea have created glowing 3D objects with a series of prototypes that fold thin QLED (Quantum Dot LED) sheets like origami. They used a CO2 laser to etch “fold lines” in the QLED so the sheets could be formed into 3D shapes. The bends are actually rounded, but at 5μm they appear to be sharp corners and the panels continue to illuminate across the fold lines for at least 500 folds. Some glow in solid colors, while others use smaller addressable areas to create animated matrix displays of patterns and letterforms. See the short video after the break, read the Physics World article or to see all the prototypes and dig into details of the full research paper in Nature (freed from the paywall by SharedIt).
We’re not sure how soon this technique can be duplicated in our home labs, but we can’t wait to fold up our own 3D lights and matrices. Until then, check out some glowing origami you can make right now from [Charlyn Gonda] at Remoticon 2020 and earlier that year and this amazing origami lamp.
Continue reading “Illuminating Origami Is Just Around The Corner”
Seoul Introduces Self-Driving Taxis
Last year the Seoul city government passed an ordinance enabling the commercial operation of autonomous passenger-carrying vehicles. A six square kilometer region in the Seoul neighborhood of Sangam, near the 2002 World Cup Stadium, was designated as a pilot program test bed. This area encompasses 24 streets totaling 31.3 km. Two companies were selected, and the pilot program launched a few weeks ago. Currently there are three vehicles and passengers can ride for free during this introductory phase. Three more taxis and a bus will be added within this year, with plans for 50 in this region by 2026. For the time being, these cars require a standby driver who takes control in an emergency and in school zones. Check out the short news report (in English) below the break.
There was a smaller autonomous driving test program in the city of Sejong which we wrote about back in January, and [Alfred Jones] gave a keynote presentation at the 2020 Hackaday Remoticon on the challenges of designing self-driving vehicles if you want to learn more on this topic.
Continue reading “Seoul Introduces Self-Driving Taxis”
South Korean KSLV-2 Nuri Rocket Almost Orbits
There was a bit of excitement recently at the Naro Space Center on Outer Naro Island, just off the southern coast of the Korea Peninsula. The domestically developed South Korean Nuri rocket departed on its inaugural flight from launch pad LB-2 at 5pm in the afternoon on Thursday, 21 Oct. The previous launch in the KSLV-2 program from this facility was in 2018, when a single-stage Test Launch Vehicle was successfully flown and proved out the basic vehicle and its KRE-075 engines.
This final version of the three-stage Nuri rocket, formally known as Korean Space Launch Vehicle-II (KSLV-2), is 47.2 m long and 3.5 m in diameter. The first stage is powered by a cluster of four KRE-075 sea-level engines having 3 MN of thrust. The second stage is a single KRE-075 vacuum engine with 788 kN thrust, and the final stage is a KRE-007 vacuum engine with 69 kN thrust (all these engines are fueled by Jet-A / LOX). In this maiden flight, the first two stages performed as expected, but something went wrong when the third stage shut off prematurely and failed to gain enough velocity to put the 1400 kg dummy satellite into orbit.
A committee formed to investigate the flight failure convened this week, and issued a statement after a preliminary review of the collected telemetry data. So far, all indications point to a drop in oxidizer tank pressure in the third stage. This could be the result of a leak in the tank itself or the associated plumbing. They will also investigate whether a sensor or other failure in the tank pressurization control system could be at fault. A second launch is currently scheduled for May of next year. Check out [Scott Manley]’s video below the break, where he discusses the launch itself and some history of South Korea’s space program.
Continue reading “South Korean KSLV-2 Nuri Rocket Almost Orbits”
1700 Regulatory Approvals Revoked In South Korea
For the first time since its inception, the Korea Communications Commission this week revoked the regulatory approvals of 1,696 telecommunications devices from 378 companies, both foreign and domestic. Those companies must recall unsold inventory from the shelves, and prove conformity of existing products already sold. In addition, the companies may not submit new applications for these items for one year. It’s not clear what would happen to already-sold equipment if the manufacturer is unable to prove conformity as requested — perhaps a recall? Caught up in this are CCTV products, networking equipment, Bluetooth speakers, and drones from companies like Huawei, DJI, and even Samsung.
The heart of the issue are what’s known as Mutual Recognition Agreements (MRAs) between countries to officially recognize of each other’s certification testing laboratories (or Conformity Assessment Bodies, CAB, in the lingo of the industry). Currently ten countries (USA, Canada, Mexico, UK, Israel, Japan, Korea, Singapore, Vietnam, and Australia), the 27 member states of the EU, Taiwan and Hong Kong all have MRAs with each other. Based on these MRAs, a Korean manufacturer could have a product tested by a laboratory in Israel, for example, and all would be kosher with the KCC.
At the center of attention is the Bay Area Compliance Laboratories (BACL), established in 1996 and headquartered in Sunnyvale, California. BACL has laboratories all over the world (USA, Taiwan, Hong Kong, Vietnam, and mainland China). Except for those in mainland China, all BACL laboratories are acceptable per the MRAs. The KCC received a tip last year that some compliance test reports for some products might be defective.
A six-month investigation in cooperation with the US National Institute of Standards and Technology (NIST) resulted in the announcement this week. Korean companies, 378 of them to be exact, had submitted test reports from BACL Sunnyvale which appeared to be appropriate. But on further investigation, it was learned that the actual testing was done by BACL laboratories in mainland China and only the reports were prepared in Sunnyvale.
It’s not clear whether these companies were knowingly playing fast and loose with the rules, whether BACL was complicit, if it was just a misunderstanding of the intricacies of the regulations and MRAs, or a combination of all three. Regardless, the KCC said that intent doesn’t matter according the their rules. It also has not been suggested that the products themselves are problematic, nor has anyone suggested that BACL’s Chinese laboratories performed slipshod work — rather, the KCC says it has no choice but to proceed with the revocation based on the applicable laws.
