72 DIY Musical Instruments Played In 7 Minutes
Humans have been making musical instruments from whatever items are close at hand for thousands of years, and we aren’t showing any signs of slowing down yet, least of all artist [Nicolas Bras] and collaborator [Sandrine Morais.] They have been designing and constructing quite a number of DIY instruments over the years, with this demo video highlighting a whopping 72 of them in the space of just seven minutes!
Clearly, [Nicolas] is one of those people who can play literally anything, and shows his skills off very well indeed if you ask us. Particularly fine sounding is the pilchards tin guitar found at 2:52 in the video, and the electric pipe beat box at 2:10 is also pretty fun.
Pretty much all the usual methods for producing sounds mechanically are covered, namely air resonating within a shaped enclosure (flutes, and such), string vibrations which might be sensed electrically (guitars, zithers, etc) and percussive instruments which vibrate an enclosed air mass (like the udu) or vibrate other things (like plates or bars). Looking over the YouTube channel, we can’t think of much they haven’t tried to make music with!
If all this sounds familiar, well, we covered [Nicolas] that time he was traveling for a gig and his instrument collection got lost in transit.
Continue reading “72 DIY Musical Instruments Played In 7 Minutes”
Nicolas Bras and his homemade musical instruments
Hacked Set Of Instruments Saves Musician’s Gigs
Most of the horror stories you hear about air travel seem to center around luggage. Airlines do an admirable job of getting people safely to their destinations, but checked baggage is a bit of a crapshoot — it could be there when you land, it could end up taking the scenic route, or it could just plain disappear. That’s bad enough when it contains your clothes, but when it contains your livelihood? Talk about stress!
This was the position musician [Nicolas Bras] found himself in after a recent trip. [Nicolas] was heading for a gig, but thanks to Brussels Airlines, his collection of musical instruments went somewhere else. There was nothing he could do to salvage that evening’s gig, but he needed to think about later engagements. Thankfully, [Nicolas] specializes in DIY musical instruments, made mostly with PVC tubes and salvaged parts from commercial instruments, so the solution to his problem was completely in his hands.
Fair warning to musical instrument aficionados — harvest the neck from a broken ukelele is pretty gruesome stuff. Attached to a piece of pallet wood and equipped with piezo pickups, the neck became part of a bizarre yet fascinating hybrid string instrument. A selection of improvised wind instruments came next, made from PVC pipes and sounding equally amazing; we especially liked the bass chromojara, sort of a flute with a didgeridoo sound to it. The bicycle pump beatbox was genius too, and really showed that music is less about the fanciness of your gear and more about the desire — and talent — to make it with whatever comes to hand.
Here’s hoping that [Nicolas] is eventually reunited with his gear, but hats off to him in the meantime for hacking up replacements. And if he looks familiar, that’s because we’ve seen some of his work before, like his sympathetic nail violin and “Popcorn” played on PVC pipes.
Continue reading “Hacked Set Of Instruments Saves Musician’s Gigs”
