Hackit: What To Do With A 1st Gen IPhone?
There’s a new iPhone 3G coming out in July. If that statement shocks you, you might want to check your connection. We love new shiny hardware, but what we’re really interested in is the number of “old” iPhones that are going to be hitting the market. Many people will be ditching their 1st generation iPhones just to get GPS and 3G. This abundance plus the new $200 price tag is bound to depress the price for used phones.
A used 1st generation iPhone is actually a pretty attractive device. It’s already been laid wide open by hackers so you can run pretty much anything you want on it instead of waiting for the App Store to tell you what you can and can’t do. You could use it as a WiFi Voip phone, a simple web pad, run an NES emulator, use it as a musical instrument, or build an army of robots.
What will you do when the price of used iPhones bottoms out?
Steven Laurie’s Art Of The Motor
We’ve served up dozens if not hundreds of machines with a practical purpose, but we are always interested in machines like those [Steven Laurie] makes, which serve no other purpose than looking impressive, spewing smoke, leaving tire marks, and making a lot of racket. We’ll give you the scoop on Steve’s motor art after the break.
Continue reading “Steven Laurie’s Art Of The Motor” →
TI-83 Intervalometer
The headline How to Make Time Lapse Video With Your DSLR didn’t really grab us. Honestly, you pay that much for a camera and it can’t do time lapse out of the box? Well, we nearly missed the real story: [Chris Martino] was using a TI-83 to act as the intervalometer for the camera. The calculator has a 2.5mm audio jack for it’s data port and the camera has an identical port for the shutter trigger. The TI-83 runs a program with a FOR loop to act as the timer. When the loop completes it sends data to the port, and the voltage triggers the shutter. The rate isn’t very exact and varies depending on the charge left in the batteries. [Chris] estimated 10000 program iterations ends up being about 26 seconds between pictures. This technique has been tested on 84, 86, and 89 series calculators too. There are a couple example time lapse videos embedded after the break.
Continue reading “TI-83 Intervalometer” →
RGB Laser Diode Projector
[fl-consult] published this interesting RGB laser diode projector. The build uses three lasers, 532nm green, 660nm red and a 405nm blue diode from an XBox 360 HD-DVD drive. Aside from the salvaged diodes, it uses some off the shelf hardware to power and scan the lasers to make the display. Details are a bit lacking, but google translate helps a bit. If you’re not quite sure what’s going on: the three lasers bounce off of a set of mirrors that scan from side to side as well as up and down to create images.
