Marvel At Soviet-era Smart Display’s Tiny Size
The Soviet-era 490IP1 LED. The digit is a mere 2.5 mm in height. Pictured with the Texas Instruments TIL306. [image: industrialalchemy.org]
It’s easy to assume that older components will be less integrated and bulkier than we might otherwise expect. Then something seems ahead of its time, like the teeny-tiny 490IP1 LED which was produced in the former Soviet Union. [AnubisTTP] obtained and shared images of this tiny integrated single digit LED display in which the number measures a scant 2.5 mm tall; in production it was made easier to read with an external bubble lens magnifier clipped to the outside. The red brick the 490IP1 is pictured with is the Texas Instruments TIL306, a relatively normal sized DIP component with similar functionality.
The 490IP1 is called an intelligent LED display because the package contains a decade counter and driver circuitry for the integrated seven-segment LED digit, complete with a carry signal that meant multiple displays could be chained together. It is notable not just due to its size, but because the glass cover makes it easy to see the die inside, as well as the wire-bonded pads.
It’s always fascinating to see glimpses of the development path that display technologies took. It’s easy to take a lot of it for granted today, but back before technology was where it is now, all sorts of things were tried. Examples we’ve seen in the past include the fantastic (and enormous) Eidophor projector which worked by drawing images onto a rotating disk of oil with an electron gun. On the smaller end of things, the Sphericular display used optics and image masks to wring a compact 0-9 numerical display out of only a few lamps at the back of a box.
14 thoughts on “Marvel At Soviet-era Smart Display’s Tiny Size
  1. So what’s up with the large pins underneath? I feel this is a plugin module and the large pins made it easier to change and also were designed to ensure a good connection in harsh environments but….
    1. I believe those “Large Pins” are actually the outside of sockets. Looks like those machined pin sockets removed from plastic.
          1. [limroh], your link worked on my PC at work, which is strange, because “work” is more selective about external links…
    2. I think those are just pin sockets. In the photo it looks like the module is driven via hidden wires poking through the cardboard or paper from underneath and connected to the sockets.
Leave a Reply to CharlesCancel reply
