Magic Acrylic Makes This Ring Stand Out
LEDs look great no matter how you use them, but sometimes you want to hide them from direct view. [Charlyn] found a great way to do that, using a special material designed just for the purpose.
[Charlyn] built a ring as a piece of fashion jewelry, hooking up a Gemma M0 microcontroller to a Neopixel Jewel, which packs 7 individual LEDs. The hardware is secreted away inside an enclosure featuring both 3D-printed and lasercut parts.
Rather than openly show off the electronics, it’s all hidden away inside. Instead, a piece of black Chemcast LED acrylic is used, which allows LED light to shine through, while otherwise appearing opaque. Those interested in learning more can check out the product details on the manufacturer site.
It’s a great way to make a subtle costume piece that only reveals its flashier side when you so decide. We’ve seen badges use similar techniques on PCBs to great effect, too. Video after the break.
Continue reading “Magic Acrylic Makes This Ring Stand Out” →
This Week In Security: Windows 10 Apocalypse, Paypal Problems, And Cablehaunt
Nicely timed to drop on the final day of Windows 7 support, Windows 10 received a fix to an extremely serious flaw in crypt32.dll. This flaw was reported by the good guys at the NSA. (We know it was the good guys, because they reported it rather than used it to spy on us.) It’s really bad. If you’re running Windows 10, go grab the update now. OK, you’re updated? Good, let’s talk about it now.
The flaw applies to X.509 keys that use elliptic curve cryptography. We’ve discussed ECC in the past, but let’s review. Public key encryption is based on the idea that some calculations are very easy to perform and verify, but extremely difficult to calculate the reverse operation.
The historic calculation is multiplying large primes, as it’s unreasonably difficult to factorize that result by a conventional computer. A true quantum computer with enough qubits will theoretically be able to factorize those numbers much quicker than a classical computer, so the crypto community has been searching for a replacement for years. The elliptic curve is the solution that has become the most popular. An agreed-upon curve and initial vector are all that is needed to perform the ECC calculation.
There are potential weaknesses in ECC. One such weakness is that not all curves are created equal. A well constructed curve results in good cryptography, but there are weak curves that result in breakable encryption.
With that foundation laid, the flaw itself is relatively easy to understand. An X.509 certificate can define its own curve. The Windows 10 implementation doesn’t properly check the curve that is specified. A malicious curve is specified that is similar to the expected curve — similar enough that the checks in crypt32 don’t catch it. Continue reading “This Week In Security: Windows 10 Apocalypse, Paypal Problems, And Cablehaunt” →
A Water Cooled Gaming PC You Can Take With You
Have you ever been stuck in a hotel room wishing you brought your VR-capable gaming PC along with you? Well [thegarbz] certainly has, which was the inspiration for this absolutely gorgeous mobile rig affectionately known as “The Nuclear Football” that brings console-level portability to those who count themselves among the PC Master Race.
OK, fine. We’ll admit that the existence of gaming laptops means you don’t actually need to carry around such an elaborate contraption just to play Steam games on the go. But if you’re going to do it, shouldn’t you do it in style? More practically speaking, [thegarbz] says the cost of this project was less than what a gaming laptop of similar specs would have cost.
The Nuclear Football features a Ryzen 5 2600 processor, a NVIDIA 2070 Super graphics card, and 16 GB of DDR4 RAM. The water cooling gear is from Alphacool, and includes a custom controller that links to the computer and allows [thegarbz] to monitor temperatures and fan speeds via a widget on the desktop.
While not nearly as mobile, this machine does remind us of the water cooled “Big O” that packed all the current-gen consoles and a gaming PC into one glorious machine.
Oceanography As Open As The Seas
With Earth in the throes of climate change and no suitable Planet B lined up just yet, oceanography is as important now as it has ever been. And yet, the instruments relied upon for decades to test ocean conditions are holding steady within the range of expensive to prohibitively expensive. Like any other area of science, lowering the barrier of entry has almost no disadvantages — more players means more data, and that means more insight into the inner workings of the briny deep.
[Oceanography for Everyone] aims to change all that by showing the world just how easy it is to build an oceanographic testing suite that measures conductivity (aka salinity), temperature, and depth using common components. OpenCTD is designed primarily for use on the continental shelf, and has been successfully tested to a depth of 100 meters.
An Adalogger M0 and RTC Featherwing run the show from their waterproof booth in the center of the PVC tube. There’s a 14-bar pressure sensor for depth, a trio of DS18B20s for temperature averaging, and a commercial conductivity probe that gathers salinity data. These sensors are fed through a 3D-printed base plate and ultimately potted in stainless steel epoxy. The other end of the tube is sealed with a mechanical plug that seats and unseats with the whirl of a wingnut.
We particularly like the scratch-built magnetic slide switch that turns OpenCTD on and off without the need to open the cylinder. If you’d like to build one of these for yourself, take a deep dive into [Oceanography for Everyone]’s comprehensive guide — it covers the components, construction, and calibration in remarkable detail. The switch is explained starting on page 50. You can find out more about the work Oceanography for Everyone is doing at their site.
As far as cheap waterproof enclosures go, PVC is a great choice. It works well for underwater photography, too.
