The original Xbox forever changed the console world, because it was basically just PC components laced together in a slightly different architecture. It featured a Pentium 733 MHz CPU with just 64MB of RAM. [Prehistoricman] has been hard at work, figuring out how to up that to 256MB instead.
This isn’t [Prehistoricman’s] first rodeo. Previously, he managed to up the Xbox’s RAM to 128 MB. To figure out how to go further, he had to figure out the addressing scheme. A datasheet for the Xbox’s original memory chip was a help in this regard, as was the envytools project and an Xbox source code leak.
A BIOS hack was needed to move the auto-precharge pin to free up more address pins for the higher memory space. Furthermore, the only available memory chips that were suitable used BGA packages, so a small PCB with castellated edges was needed to adapt the chip to the Xbox’s motherboard, which expects a TQFP package.
Ultimately, getting this hack to work involved a lot of bare-metal hacking. It also won’t help the performance of commercial games at all, as they were all designed within the limitations of the original console. Still, it’s impressive to see this now-ancient platform hacked to do more. It’s also hilarious to compare it with a contemporary PC, which could simply accept 256 MB of RAM by using additional memory slots. Video after the break.
Continue reading “Giving The Original Xbox 256 MB Of Memory”
