Fiddle around with cars long enough and you’ll realize two things: first, anything beyond the simplest repairs will probably require some kind of specialized tool, and second, those tools can be prohibitively expensive. That doesn’t mean you’re out of luck, though, especially if you’ve got scrap galore and a DIY spirit, as this junk bin fuel injector test stand ably demonstrates.
[Desert Rat Racer]’s test rig is designed to support four injectors at once and to test them under conditions as close as possible to what they’ll experience when installed. To that end, [Rat] mounted a junk intake manifold to a stand made from scrap wood and metal found by the side of the road. A pickle jar serves as a reservoir for the test fluid — he wisely used mineral spirits as a safer substitute for gasoline — and a scrap electric fuel pump pressurizes a junk fuel rail, which distributes fuel to the injectors under test.
For testing, the injectors are wired up to an electric injector tester, which is one of the few off-the-shelf components in the build. The fuel pump and injectors are powered by the 12 volt rail of a scrapped PC power supply. Just being able to watch the spray pattern is often enough to find a faulty injector, but in case a more quantitative test is indicated, each injector is positioned over a cheap glass cylinder to catch the test fluid, and scraps of a tape measure are used to measure the depth of the collected fluid. No fancy — and expensive — graduated cylinders required.
While we truly respect the hackiness of [Desert Rat Racer]’s build, the concept of avoiding buying tactical tools is foreign to us. We understand the logic of not dropping a ton on a single-use tool, but where’s the fancy blow-molded plastic case?
Continue reading “Junk Bin Build Lets You Test Fuel Injectors On The Cheap” →
