The laptop to have here in the 2020s varies depending on who you ask, perhaps a Framework, or maybe a ThinkPad. Back in the 1990s the answer might have included a now-forgotten contender, because in that decade Toshiba made a range of legendarily tough chunky grey machines. Of these the smallest was the Libretto, a paperback book sized clamshell design which was an object of desire. It’s one of these that [Robert’s Retro] has upgraded to use USB-C power instead of the original power brick.
The full video is below the break, and while it first deals with replacing a defective screen, the power part starts just before 22 minutes in. As you’d expect it involves a USP-C PD trigger board, this time at 15 volts. It’s mounted in a small 3D printed adapter to fill the space of the original jack, and requires a tiny notch be removed from the corner of its PCB to fit round the motherboard. The rest of the video deals with reassembling the machine and tending to mishaps with the ageing plastic, but the result is a Libretto with a modern charging port.
Naturally a machine with a Pentium CPU and 32 megabytes of RAM is in of limited use in modern terms, but these Librettos remain very well-designed tiny PCs to this day. It’s great to see them still being modified and upgraded, even if perhaps there’s a limit to how far you can push their computing power. We’ve encountered the Libretto before a few times, such as when one was used to retrieve data from an old Flash card.
