First of all, we’d like to give a big shout-out to [Afrotechmods]! After a long hiatus, he has returned to YouTube with an awesome new video all about op-amp characteristics, looking at the relatively awful LM741 in particular. His particular way of explaining things has definitely helped many electronics newbies to learn new concepts quickly!
Operational amplifiers have been around for a long time. The uA741, now commonly known as the LM741, was indeed an incredible piece of technology when it was released. It was extremely popular through the 1970s and onward as it saved designers the chore of designing a discrete amplifier. Simply add a few external components, and you have a well-behaved amplifier.
One of the most exciting trends we’ve seen over the last few years is the rise of truly personal computers — that is, bespoke computing devices that are built by individuals to fit their specific needs or wants. The more outlandish of these builds, often inspired by science fiction and sporting non-traditional layouts, tend to be lumped together under the term “cyberdecks”, but there are certainly builds where that description doesn’t quite stick, including the Cyber Writer from [Darbin Orvar].
With a 10-inch screen, you might think it was intended to be a portable, but its laser-cut Baltic birch plywood construction says otherwise. Its overall design reminds us of early computer terminals, and the 60% mechanical keyboard should help reinforce that feeling that you’re working on a substantial piece of gear from yesteryear.
There’s plenty of room inside for additional hardware.
The Cyber Writer is powered by the Raspberry Pi Zero W 2, which might seem a bit underpowered, but [Darbin] has paired it with a custom minimalist word processor. There’s not a lot of detail about the software, but the page for the project says it features integrated file management and easy email export of documents.
The software isn’t yet available to the public, but it sounds like [Darbin] is at least considering it. Granted, there’s already distraction-free writing software out there, but we’re pretty firm believers that there’s no such thing as too many choices.
Early photography lacked the convenience of the stable roll film we all know, and instead relied on a set of processes which the photographer would have to master from film to final print. Photographic chemicals could be flammable or even deadly, and results took a huge amount of work.
We know so much about the other processes because they were subject to patents, but pannotype never had a patent due to a disagreement. Thus when the conservators encountered some pannotypes in varying states of preservation, they needed to apply modern analytical techniques to understand the chemistry and select the best methods of stabilization. The linked article details those analyses, and provides them with some pointers towards conserving their collection. We look forward to someone making pannotype prints here in 2025, after all it’s not the first recreation of early photography we’ve seen.
Lord Vetinari from the Discworld series is known for many things, but perhaps most of all a clock that doesn’t quite keep continuous time. Instead, it ticks away at random increments to infuriate those that perceive it, whilst keeping regular time over the long term. [iracigt] decided to whip up a real world version of this hilarious fictional timepiece.
The clock itself is an off-the-shelf timepiece purchased from Target for the princely sum of $5. However, it’s been deviously modified with an RP2040 microcontroller hidden away inside. The RP2040 is programmed to tick the clock at an average of once per second. But each tick itself is not so exact. Instead, there’s an erraticness to its beat – some ticks are longer, some shorter, in the classic Vetinari style. [iracigt] explains the nitty gritty of how it all works, from creating chaos with Markov chains to interfacing the RP2040 electronically with the cheap quartz clock movement.
If you’ve ever wanted to build one of these amusements yourself, [iracigt’s] writeup is a great place to start. Even better, it was inspired by an earlier post on these very pages! We love to see the community riff on a theme, and we’d love to see yours, too – so keep the tips coming, yeah? Video after the break.
Many of us know the basic Blink Arduino sketch, or have coded similar routines on other microcontrollers. Flashing an LED on and off—it doesn’t get much simpler than that. But how big should a blink sketch be? Or more importantly, how small could you get it? [Artful Bytes] decided to find out.
The specific challenge? “Write a program that runs on a microcontroller and blinks an LED. The ON and OFF times should be as close to 1000 ms as possible.” The challenge was undertaken using a NUCLEO-L432KC Cortex-M4 with 256 K of flash and 64 K of RAM.
We won’t spoil the full challenge, but it starts out with an incredibly inefficient AI & cloud solution. [Artful Bytes] then simplifies by switching to an RTOS approach, before slimming down further with C, assembly, and then machine code. The challenge was to shrink the microcontroller code as much as possible. However, you might notice the title of the video is “I Shrunk Blinky to 0 Bytes.” As it turns out, if you eliminate the digital code-running hardware entirely… you can still blink an LED with analog hardware. So, yes. 0 bytes is possible.
When a Loch Ness Monster story appears at the start of April, it pays to check the date on the article just to avoid red faces. But there should be no hoax with this one published on the last day of March, scientists from the UK’s National Oceanography Centre were conducting underwater robotics tests in Scotland’s Loch Ness, and stumbled upon a camera trap lost by Nessie-hunters in the 1970s. Just to put the cherry on the cake of a perfect news story, the submarine in question is the famous “Boaty McBoatface”, so named as a consolation after the British Antarctic Survey refused to apply the name to their new ship when it won an online competition.
The Most Extreme Instamatic in The World
Sadly the NOC haven’t released close-ups of the inner workings of the device.
The camera trap has survived five decades underwater thanks to a sturdy glass housing, and appears to be quite an ingenious device. A humble Kodak Instamatic camera with a 126 film and a flash bulb is triggered and has its film advanced by a clockwork mechanism, in turn operated by a bait line. Presumably because of the four flash bulbs in the Kodak’s flash cube, it’s reported that it could capture four images. The constant low temperature at the bottom of a very deep loch provided the perfect place to store exposed film, and they have even been able to recover some pictures. Sadly none of then contain a snap of Nessie posing for the camera.
While there’s still a vaguely robot-shaped hole in our heart from the loss of the New York World Maker Faire, we do take comfort in the fact that smaller Maker Faire events are still happening all over the world, and some of them have managed to gain quite a bit of momentum over the last few years.
If you’re in the Northeast US, the Philadelphia Maker Faire is your best bet to scratch that peculiar itch that only seems to respond to a healthy blend of art, technology, and the occasional flamethrower. It will be returning to the Cherry Street Pier this Sunday, April 6th, and pay-what-you-can tickets are on sale now. The organizers encourage each attendee to only pay what they are able to afford, with several options ranging from zero to the $25 supporter level.
A look through the exhibits shows the sort of eclectic mix one would expect from a Maker Faire. Where else could you practice picking locks, learn how biodiesel is made, see a display of kinetic sculptures, and stitch together a felt plush monster, all under one roof?
We’ve made the trip to the Philadelphia Maker Faire several times since its inception in 2019, and although it had the misfortune of starting right before COVID-19 came along and screwed up all of our carefully laid plans, the event has managed to find a foothold and continues to grow each year.
