Ask Hackaday: Do We Need A 21st Century Calculator?
The HP-41C analog on my phone gives the right answer.
Three resistors in parallel: 4.7 k,Ω 22 kΩ, and 3.3 kΩ. Quick! What’s the equivalent value? You can estimate it, of course, but if you want the actual 1.8 kΩ (approximately) answer, you probably reached for some kind of calculating aid. I have two slide rules on my desk, and plenty more a few steps away, but I don’t use them much, honestly. I have a very old HP-41C — arguably the best calculator ever made — but I am usually afraid to use it as it is almost 50 years old and difficult to repair. I also have an HP-28S on my desk, a replica HP-41C, and a few others in desk drawers. There are also dozens of calculators on my desktop computer, my phone –including the official HP Prime app — and the web browser.
I often see newer calculators from HP, like the Prime G2, or “new” HP-like calculators like the ones from SwissMicros, and think I should pick one up. Well, technically, HP licensed their calculators to Moravia, so even a “real” HP calculator isn’t from HP anymore. But, in the end, I always realize that my need for a physical calculator is so diminished that I can’t justify buying anything new, and I can barely even spring for a $10 one at the thrift store unless it is a real collectible.
Mind you, I’m not talking about RPN versus algebraic. I could say the same thing for TI, Casio, or Sharp calculators. I just don’t know why I need one anymore, even though I still, for some strange reason, want them.
The Prime seems impressive, if I could ever find time to finish reading the manual.
For the record, I did use an HP-41C to check the resistor math, but it was in the form of an app on my phone, not a real calculator. On the same computer I’m writing this on, I have HP-41C emulators, the Prime emulator, and a bunch of other calculators. Yet I still pick up my phone and use the familiar key layout of the HP-41C. I don’t know why. The replica 41C, unfortunately, has a landscape-oriented keyboard, so while I like it, it doesn’t satisfy my finger’s muscle memory.
Which leads to this Ask Hackaday. Do you use a calculator? Why? If you don’t, do you use a fake calculator on your phone or computer? Or do you just send your math to Google or Wolfram? I suspect some of the answer will be generational. I was in high school before calculators started showing up in schools, but they took over quickly.
There is something satisfying about having a purpose-built device to do your math. No long boot sequence. No switching apps. No messages coming in while you are typing in numbers. For the ultimate convenience, you could wear it on your wrist. The Apollo mission that docked with a Russian spacecraft carried an HP-65, and nine early Space Shuttle missions used an HP-41C. But even astronauts now don’t have a standard-issue calculator. Pilots sometimes use electronic E6Bs, but many still use the mechanical version.
Of course, I do collect slide rules, so maybe I just need to accept that calculators are yet another tech relic to collect. But someone is still buying them. I’d like to be one of them.
With the current state of tech, you can easily build your own calculators. There are several options.
83 thoughts on “Ask Hackaday: Do We Need A 21st Century Calculator?”
  1. I’d actually love to have a calculator that would run something like Mathcad. A (relatively) large (touch?) screen that shows the canvas, and a real keyboard to type in stuff. But all pocket sized, or at least the size of a TI-84.
    Or maybe a landscape form factor like a Casio FX-850, because typing on a real qwerty keyboard is so much easier and faster. No need for all those math function keys or a separate numerical keypad. Smart predictive text would quicken the typing. And if the screen is a touch screen, there’s another level of input (selection, copy&paste, context menus). Multi touch of course.
    I think I’m basically talking about a Blackberry, but with a hires touchscreen. Maybe a bit larger screen than 2.8″, but it should still fit in a normal pocket. There are quite cheap Blackberry-like phones on Aliexpress that could probably be hacked with Mathcad-like firmware (ok, you could run an app, but I’d like it purpose-built).
    But they al lack one important thing on the keyboard: no row of number keys and no special character keys that can be used directly (i.e. without using a shift key or whatever).
  2. I use the i42cx app on my phone and tablet. I recently started using a slide rule for the first time and really like it. I’m of an age that never really saw slide rules used in school as calculators killed them pretty fast. I have a new appreciation for the 8nsights they can give on the math.
    In 1991 I bought a brand new HP 32S ii. It has been my daily use calculator ever since. It has followed me over 3 million air miles and is still working great. The most impressive thing about this calculator is that I’ve never replaced the batteries! Yes, 35 years of daily use with the original batteries!
  3. I admit to having the occasional hankering for an APL calculator, using the original overstrike keyboard which was far more manageable than the later ones with hundreds of symbols.
    No real application for it, just nerdiness.
    And yes, I do usually use an RPN HP.
  4. I love my calculators, one device doing what is was made for.
    My HP (HP11C) here at my desk and then the casio (FX-998DE X) that is used at my childrens school. Just switch it on an all needed functions are one (or two) fingertips away, no starting of an app on my phone or program on the computer.
