Around October, amid all the pumpkin spiced food and beverages, folks make their yearly pilgrimage to a local farm. They load themselves onto hay-filled tractor trailers and ride out in search of the perfect pumpkin to put on the front porch, and let it slowly decompose. The “closest” a video game has come to replicating this seasonal event is the annual Farming Simulator series. One modder, [Dylan], decided to add an extra level of authenticity to the Farming Simulator experience by controlling the game with an actual tractor.
The opportunity for the project presented itself thanks to a local Kiwi farmer (Kiwi as in New Zealand, not the fruit) who provided [Dylan] with access to a Case IH 310 Magnum CVT tractor. [Dylan] built a custom USB controller that mirrored the actual layout of the tractor’s control pad. Tilt sensors were wrapped around the tractor’s steering wheel and throttle to provide analog input for steering and speed control. After a number of hours tweaking the setup on site, [Dylan] live-streamed his Farming Simulator PC play session (video below) with the tractor itself left off for obvious reasons. Without tractor motor engaged there was no power steering, so he deserves a bit of extra credit for making it through multiple hours.
This certainly isn’t the first ridiculous controller project [Dylan] has taken on. He’s created a trombone controller to just to play Trombone Champ, a Nerf bow controller for Overwatch, and he even played through Hades using a literal pomegranate. You can watch more of [Dylan’s] custom controller projects on his Rudeism Twitch channel.
Continue reading “Real Tractor Moonlights As Farming Simulator Controller”
