Electric Motorcycles Don’t Have To Be Security Nightmares, But This One Was
Once upon a time, they told us we wouldn’t download a car, and they were wrong. Later, Zero Motorcycles stated in their FAQ that you cannot hack an electric motorcycle, a statement which [Persephone Karnstein] and collaborator [Mitchell Marasch] evidently took issue with. Not only can you hack an electric motorcycle, it is — in [Persephone]’s words — a security nightmare.
You should absolutely go over to [Persephone]’s website and check out the whole write-up, which is adapted from a talk given at BSides Seattle 2026. There’s simply way more detail than we can get into here. Everything from “what horridly toxic solvents would I need to unpot this PCB?” to the scripts used in de-compiling and understanding code, it’s all there, and in a lively and readable style to boot. Even if you have no interest in security, or electric motorcycles, you should check it out.
The upshot is that not only were Zero Motorcycles wrong when they said their electric motorcycles could not be hacked, they were hilariously wrong. The problem isn’t the motorcycle alone: it has an app that talks to the electronics on the bike, which take over-the-air (OTA) updates. What about the code linked to the VIN alluded to in that screenshot? Well, it turns out you just need a code structured like a VIN, not an actual number. Oops. By the end of it, [Persephone] and [Mitchell] have taken absolute control of the bike’s firmware, an so have them full control over all its systems.
Why cut the brake lines when you can perform an OTA update that will do the same thing invisibly? And don’t think you can just reset the bike to factory settings to fix it: they thought of this, and the purely-conceptual, never-deployed malware has enough access to prevent that. Or they could just set the battery on fire. That was an option, too, because the battery management system gets OTA updates as well.
To be clear, we don’t have any problem with a motorcycle that’s dependent on electronics to operate. After all, we’ve seen many projects that would meet that definition over the years. But the difference is none of those projects fumbled the execution this badly. Even this 3 kW unicycle, which has a computer for balance control, doesn’t see the need to expose itself. It’s horribly unsafe in very different ways.
US FCC Prohibits Approval Of New Foreign-Made Consumer Routers
The US Federal Communications Commission (FCC) is tasked with regulating both wired and wireless communications, which also includes a national security component. This is how previously the FCC tossed networking gear made by Huawei and foreign-manufactured drones onto its Covered List, effectively banning it from sale in the US. Now foreign-made consumer routers have been added to this list, barring explicit conditional approval on said list that would exempt them during a ‘transition phase’.
As per the FCC fact sheet, this follows after determination by an interagency body that such routers “pose unacceptable risks to the national security of the United States [..]”. This document points us to the National Security Determination PDF, which attempts to lay out the reasoning. In it is noted that routers are an integral part of every day life, and compromised routers are a major risk factor, ergo it follows that only US-manufactured routers are to be trusted.
These – so far fictional – US-manufactured consumer routers would have to feature ‘trusted supply chains’, which would seem to imply onshoring a large industrial base, though without specifying how deep this would have to go it’s hard to say what would be involved. The ‘supporting evidence’ section also only talks about firmware-related vulnerabilities, which would imply that US firmware developers do not produce CVEs.
Continue reading “US FCC Prohibits Approval Of New Foreign-Made Consumer Routers”
The ‘Hidden’ Microphone Inside The Sipeed NanoKVM
Recently, [Jeff Geerling] dropped into the bad press feeding frenzy around Sipeed’s NanoKVM, most notably because of a ‘hidden’ microphone that should have no business on a remote KVM solution. The problem with that reporting is, as [Jeff] points out in the video below, that the NanoKVM – technically the NanoKVM-Cube – is merely a software solution that got put on an existing development board, the LicheeRV Nano, along with an HDMI-in board. The microphone exists on that board and didn’t get removed for the new project, and it is likely that much of the Linux image is also reused.
Of course, the security report that caused so much fuss was published back in February of 2025, and some of the issues pertaining to poor remote security have been addressed since then on the public GitHub repository. While these were valid concerns that should be addressed, the microphone should not be a concern, as it’d require someone to be logged into the device to even use it, at which point you probably have bigger problems.
Security considerations aside, having a microphone in place on a remote KVM solution could also be very useful, as dutifully pointed out in the comments by [bjoern.photography], who notes that being able to listen to beeps on boot could be very useful while troubleshooting a stricken system. We imagine  the same is true for other system sounds, such as fan or cooling pump noises. Maybe all remote KVM solutions should have microphone arrays?
Of course, if you don’t like the NanoKVM, you could always roll your own.
Top image: the NanoKVM bundle from [Jeff]’s original review. (Credit: [Jeff Geerling])
Continue reading “The ‘Hidden’ Microphone Inside The Sipeed NanoKVM”
New Bambu Lab Firmware Update Adds Mandatory Authorization Control System
As per a recent Bambu Lab blog post, its FDM printers in the X1 series will soon receive a firmware update that adds mandatory authentication for certain operations, starting with the firmware update on January 23rd for the aforementioned FDM printers. These operations include performing firmware upgrades, initiating a print job (LAN or cloud), remote video access and adjusting parameters on the printer. Using the printer directly and starting prints from an SD card are not affected.
As reasoning for this new feature Bambu Lab points to recent exploits that gave strangers access to people’s printers, though cheekily linking to an article on an Anycubic printer exploit. While admittedly a concern, this mostly affects internet-exposed printers, such as those that are tied into a ‘cloud’ account. Even so, LAN-based printing also falls under this new mandatory authentication system, with Bambu Lab offering a new tool called Bambu Connect for those who insist on using non-Bambu Lab branded software like OrcaSlicer. This allows for exported G-code files to be sent to a (property authenticated) Bambu Lab printer.
For those who do not wish to use this feature, not upgrading the firmware is currently the only recourse. Although this firmware update is only for X1-series printers, Bambu Lab promised that it’ll arrive for their other printers too in due time. While Bambu Lab printer owners consider installing the alternative X1 Plus firmware, the peanut gallery can discuss the potential security issues (or lack thereof) of an open Fluidd or similar UI on their LAN-connected, Klipper-based FDM printers.
Thanks to [mip] for the tip.
Imperva Report Claims That 50% Of The World Wide Web Is Now Bots
Automation has been a part of the Internet since long before the appearance of the World Wide Web and the first web browsers, but it’s become a significantly larger part of total traffic the past decade. A recent report by cyber security services company Imperva pins the level of automated traffic (‘bots’) at roughly fifty percent of total traffic, with about 32% of all traffic attributed to ‘bad bots’, meaning automated traffic that crawls and scrapes content to e.g. train large language models (LLMs) and generate automated content as well as perform automated attacks on the countless APIs accessible on the internet.
According to Imperva, this is the fifth year of rising ‘bad bot’ traffic, with the 2023 report noting again a few percent increase. Meanwhile ‘good bot’ traffic also keeps increasing year over year, yet while these are not directly nefarious, many of these bots can throw off analytics and of course generate increased costs for especially smaller websites. Most worrisome are the automated attacks by the bad bots, which ranges from account takeover attempts to exploiting vulnerable web-based APIs. It’s not just Imperva who is making these claims, the idea that automated traffic will soon destroy the WWW has floated around since the late 2010s as the ‘Dead Internet theory‘.
Although the idea that the Internet will ‘die’ is probably overblown, the increase in automated traffic makes it increasingly harder to distinguish human-generated content and human commentators from fake content and accounts. This is worrisome due to how much of today’s opinions are formed and reinforced on e.g. ‘social media’ websites, while more and more comments, images and even videos are manipulated or machine-generated.
Social Engineering Is On The Rise: Protect Yourself Now
As Internet security has evolved it has gotten easier to lock your systems down. Many products come out of the box pre-configured to include decent security practices, and most of the popular online services have wised up about encryption and password storage. That’s not to say that things are perfect, but as the computer systems get tougher to crack, the bad guys will focus more on the unpatchable system in the mix — the human element.
History Repeats Itself
Ever since the days of the ancient Greeks, and probably before that, social engineering has been one option to get around your enemy’s defences. We all know the old tale of Ulysses using a giant wooden horse to trick the Trojans into allowing a small army into the city of Troy. They left the horse outside the city walls after a failed five-year siege, and the Trojans brought it in. Once inside the city walls a small army climbed out in the dead of night and captured the city.
How different is it to leave a USB flash drive loaded with malware around a large company’s car park, waiting for human curiosity to take over and an employee to plug the device into a computer hooked up to the corporate network? Both the wooden horse and the USB drive trick have one thing in common, humans are not perfect and make decisions which can be irrational. Continue reading “Social Engineering Is On The Rise: Protect Yourself Now”
Yet Another IoT Botnet
[TrendMicro] are reporting that yet another IoT botnet is emerging. This new botnet had been dubbed Persirai and targets IP cameras. Most of the victims don’t even realize their camera has access to the Internet 24/7 in the first place.
Trend Micro, have found 1,000 IP cameras of different models that have been exploited by Persirai so far. There are at least another 120,000 IP cameras that the botnet could attack using the same method. The problem starts with the IP cameras exposing themselves by default on TCP Port 81 as a web server — never a great idea.
Most IP cameras use Universal Plug and Play, which allows them to open ports from inside the router and start a web server without much in the way of security checks. This paints a giant target in cyber space complete with signs asking to be exploited. After logging into a vulnerable device the attacker can perform a command injection attack which in turn points gets the camera to download further malware.
The exploit runs in memory only, so once it has been rebooted it should all be fine again until your next drive by malware download. Check your devices, because even big named companies make mistakes. IoT is turning into a battlefield. We just hope that with all these attacks, botnets, and hacks the promise of the IoT idea isn’t destroyed because of lazy coders.
Part of feature image from Wikipedia, Creative Commons license.
