Digital Wind Chimes
Quality wind chimes are not cheap. No matter how much you spend, though, they generally sound the same year after year. If that bothers you, maybe [sensatroniclab] can help. They’ve posted a simple design for a digital wind chime using the Ototo music generator.
The Ototo is reasonably priced and promises to let you make music from anything (well, anything conductive, anyway).  Because the Ototo handles all the music production, the only real building part of the project is the wind sensors. The sensors are made with conductive fabric with a marble at the end for weight.
In the video below you can see [Matthew Ward] talk about the device and actually play it like you might a harp. This would be a good school project owing to the simplicity of using the Ototo, although [sensatroniclab] is actually working on accessibility music projects.
Continue reading “Digital Wind Chimes” →
Electronic Wind Chime
The Winduino II uses fins to pick up the movement of the wind and translate it into music. Each fin is attached to the main body using a piezo vibration sensor. The signals are processed by an Arduino housed inside and the resulting data makes its way to a computer via a Bluetooth connection to facilitate the use of Max/MSP for the audio processing. Included in the design is an array of solar panels used to keep the battery for the device charged up. Hear and see this creative piece after the break.
Continue reading “Electronic Wind Chime” →
