Homemade UAV
uav
[Terence Bordelon] sent in his impressive UAV (Unmanned Arial Vehicle). The hack is a culmination of his other projects. It can be turned to fully automatic at the flip of a switch. It will fly itself to gps way points, land, and take off. The UAV has a range of 100km thanks to his home built RF Unit which runs on ham bands. The brains of the setup is his custom IMU (Inertial Measurement Unit). The unit is controlled by his ground station which either allows him to fly it normally or toggle through the various modes.  [Terrence] is also a game developer and has worked on many popular titles such as Zoo Tycoon 2 and Ratchet and Clank.
Word Clock: Tell The Time With Words
wordclock
[drj113]  posts his cool word clock. After seeing a similar clock on an industrial design website, he set out to make his own version. He made custom pcbs with the toner-etch method. The front is a solid piece of copper clad board and the light shines through the etched areas. It’s powered by a PIC microcontroller and uses approximately 120 ultra bright LEDs. [drj113] has all of the circuit board diagrams, silkscreens, etch negatives, and code on the intructable so you can build your own.
Unhackable Netbooks Given To Students
nb
Where would be the best place to test out an unhackable netbook? The NSW department of education in Australia thinks that college is perfect . They plan on distributing netbooks, preloaded with Windows 7,and iTunes. They also have bios level tracking and security, allowing them to be remotely shut down on command. With 20,000 of these in circulation, we would think that we’ll see someone proving the “unhackable” statement wrong. We can only hope.
[via slashdot]
