Lasers are such a fundamental piece of technology today that we hardly notice them. So cheap that they can be given away as toys and so versatile that they make everything from DVD players to corneal surgery a reality, lasers are one of the building blocks of the modern world. Yet lasers were once the exclusive province of physicists, laboring over expansive and expensive experimental setups that seemed more the stuff of science fiction than workhouse tool of communications and so many other fields. The laser has been wildly successful, and the story of its development is an intriguing tale of observation, perseverance, and the importance of keeping good notes.
Day: January 8, 2018
The Majesty Of Saturn’s Rings Lighting Your Abode
[Modustrial Maker] is at it again with another seriously cool LED visualizer. This time around, he’s built pair of pendant lights inspired by the rings of Saturn.
The rings are made mostly of walnut plywood using a circle router jig to make the cut easier. If you are inspired to make these for yourself, [Modustrial Maker] is clear — the order in which you cut out the pieces of the rings is absolutely critical. The pieces are glued together — with any edges sanded smooth — and edgebanding applied using a hot air gun due to the curved surface before staining. Duplicate for the second (or more if you so choose!) rings. Be forewarned — a little geometry will be needed to find anchor points that will keep the rings properly balanced.
[Modustrial Maker] suggests an off-the shelf LED controller to handle the visualizations and lighting effects, but he used an Arduino Mega clone as the brains — code available here, a MonkeyJack MAX9814 electret mic, and a four-channel RF remote/transceiver to control the different modes. Pulsing along to the music, these rings make for sleek lighting indeed.
Continue reading “The Majesty Of Saturn’s Rings Lighting Your Abode”
Mom, I’ll Be In My Attic Spaceship
Most attics sit empty or serve as storage space to keep infrequently used items out of sight. Many of us keep boxes of half-completed abandoned projects there. But some people turn the attic itself into the project: this past Christmas some very lucky children received a spaceship playroom in the attic. [Titospot] shared his project via an Imgur album.
The cramped space lends itself to the theme as real-life spacecraft have never been known for interior spaciousness. The builders are skilled enough at standard home improvement tasks of building out and finishing a room, then they took their step into the unknown by building a control panel for the spaceship. [Titospot’s] caption text reveals some insecurity with his electronics build quality but, hey, we all had to start somewhere! Few of our first electronics projects were as much fun as his spaceship control panel. Packed with buttons and switches that trigger light and sound, it is sure to become the focus of many imaginary adventures to galaxies far, far away.
