If you write software, chances are you’ve come across Continuous Integration, or CI. You might never have heard of it – but you wonder what all the ticks, badges and mysterious status icons are on open-source repositories you find online. You might hear friends waxing lyrical about the merits of CI, or grumbling about how their pipeline has broken again.
Join Hackaday in Belgrade, Serbia on May 9th, 2020 for the Hackaday Belgrade conference! The biennial hardware conference is just seventeen weeks from now. Early Bird tickets will go on sale shortly, but beginning right now you can hack your way into the conference by submitting a talk proposal. Accepted speakers receive free admission, plus everyone who submits a quality talk proposal will be given priority when tickets go on sale.
Yes, I’m talking to you. Hackaday strives to include first-time speakers in the slate of presenters at our conferences. We’re looking for unique, cutting-edge, whimsical, crazy, formidable, or world-changing topics revolving around hardware creation. From learning new tools or techniques to fabrication adventures, from code-wrangling that firmware project to pulling off an art installation, and from forgotten hardware history to the impossible made possible on your own workbench, we need to hear your stories!
That project for which you went into the deep weeds and worked your way back out again? Everyone at a Hackaday conference wants to hear about it and in the greatest detail possible. After all, we’re your fellow hackers. In fact, you should probably bring the hardware along for the ride.
We Need You
None of this happens in a vacuum. This is the third Hackaday Belgrade conference, which have now settled into a tick-tock cadence of even-numbered years. The first two both sold out, this one will as well, and the result is always an action-packed, nearly 24-hour marathon sprint of talks, workshops, and hardware hacking. But the only reason this works is because amazing people just like you make it a priority in their life to be there.
Badge hacking at 2018 Hackaday Belgrade
So take the plunge, put together your talk proposal and submit it before March 2nd. But don’t stop there, pester your friends and your heros to do the same. Block out May 9th on your schedule (roughly 9 am-2 am) and take the day before off of work. While you’re at it, convince your boss and coworkers to come along with you. See you in Belgrade!
Sometimes it’s ok to sacrifice some practicality for aesthetics, especially for passion projects. Falling solidly in this category is [Peter Forsberg]’s beautiful, barely functional steam punk motorcycle. If this isn’t hacker art, then we don’t know what is.
The most eye-catching part of the motorcycle is the engine and drive train, with most of the mechanical components visible. The cylinders are clear glass tubes with custom pistons, seals, valves and push rods. The crank mechanism is from an old Harley and is mounted inside a piece of stainless steel pipe. Because it runs on compressed air it cools down instead of heating up, so an oil system is not needed.
For steering, the entire front of the bike swings side to side on hinges in the middle of the frame, which is quite tricky to ride with a top speed that’s just above walking speed. It can run for about 3-5 minutes on a tank, so the [Peter] mounted a big three-minute hour glass in the frame. The engine is fed from an external air tank, which he wears on his back; he admits it’s borderline torture to carry the thing for any length of time. He plans to build a side-car to house a much larger tank to extend range and improve riding comfort.
[Peter] admits that it isn’t very good as a motorcycle, but the amount of creativity and resourcefulness required to make it functional at all is the mark of a true mechanical hacker. We look forward to seeing it in its final form.
When you need coffee, you don’t need any hassles standing between you and caffeination. Especially ironic hassles, like having to do more to turn on appliances inside of home automation schemes than you did without them.
[Maurice Makaay] bought a smart plug to add this beautiful drip coffee machine to his Z-Wave setup, but it isn’t all that smart. Starting the brew remotely means making sure that both the machine’s power switch and the smart plug switch are on. Some members of the household still like making their coffee the old-fashioned way, so [Maurice] came up with a smart, single switch solution to satisfy both cases.
[Maurice] went about this mains appliance hack the right way — he used extra thick wires connected with lever nuts, and kept the machine’s equally beautiful spare parts and safety documentation by his side the whole time. A person could probably become a lot more comfortable with the idea of installing these by looking over [Maurice]’s pictures of the process.
You know how coffee makes everything better? Turns out ‘everything’ includes printer filament.
