That Time NASA Built A Tiny Tank To Pop Shuttle Tires
The Space Shuttle has often been called the most complex pieces of machinery ever built, an underhanded compliment if there ever was one. But it’s a claim not strictly limited to the final spacecraft. With a project as far ahead of the technological curve as the Shuttle was in the 1970s, nearly every component and system of the legendary spaceplane required extensive research and development to realize.
A case in point is that the speed and mass of the Shuttle at touchdown required tires that could survive forces far beyond that of a normal airplane. Pumped up to an incredible 350 psi, the space agency estimated each tire had the explosive potential of two and one-half sticks of dynamite. So while testing landing gear upgrades in the 1990s, they cobbled together an RC tank that could “defuse” a damaged tire remotely by drilling holes into it and letting off the pressure. Continue reading “That Time NASA Built A Tiny Tank To Pop Shuttle Tires”
This Week In Security: SSH, FTP, And Reptar
It’s time to strap on our propeller beanies, because we’re going to talk crypto. The short version is that some SSH handshakes can expose enough information for a third party to obtain the host’s private signing key. That key is the one that confirms you are connecting to the SSH server you think you are, and if the key validation fails, you get a big warning:
@ WARNING: REMOTE HOST IDENTIFICATION HAS CHANGED! @
IT IS POSSIBLE THAT SOMEONE IS DOING SOMETHING NASTY!
The math that makes this warning work is public-private key cryptography. The problem we’re talking about today only shows up in RSA authentication. Specifically those that use the Chinese Remainder Theorem (CRT) to quickly calculate the modulos needed to generate the cryptographic signature. If something goes wrong during that calculation, you end up with a signature that is mathematically related to the secret key in a different way than intended. The important point is that knowing this extra value *significantly* weakens the security of the secret key.
This attack has been known for quite some time, but the research has been aimed at causing the calculation fault through power vaults or even memory attacks like Rowhammer. There has also been progress on using a lattice attack against captured handshakes, to make the attack practical with less known information. The real novel element of this week’s approach (pdf) is that it has been tested against SSH.
The paper’s authors performed weekly scans of the entire IPv4 public network space, capturing the handshake from any listening SSH server, and also had 5 years of historic data to draw from. And the results are mixed. There is a Cisco SSH server string that is extremely common in the dataset, and only once did one of these machines send a miscalculated handshake. Possibly a random ram bit flip to blame. And on the other hand, the string “SSH-2.0-Zyxel SSH server” had so many bad signatures, it suggests a device that *always* sends a miscalculated signature. Continue reading “This Week In Security: SSH, FTP, And Reptar”
Taking A Public Transit Display From Project To Product
We’ve noticed an uptick in “project to product” stories lately, which seems like a fantastic trend to us. It means that hackers are turning out projects that really resonate with people, to the degree that taking the leap and scaling up from a one-off to a marketable product is worth the inherent risk. And luckily enough for the rest of us, we get to learn from their experiences.
The latest example of this comes to us from [Stefan Schüller], who from the sound of things only reluctantly undertook the conversion of his LED matrix public transit sign into an actual product. The original project had a lot going for it; it looked fantastic, it was technologically simple, and it provided a valuable service. But as a project, it made certain assumptions and concessions that would cause problems when in the hands of a customer. Chief among these was the physical protection of the fragile LEDs, which could easily shear off the display modules if bumped or dropped. There were also firmware issues, such as access to the backend API that serves the transit data; requiring each customer to sign up for and configure their own API key is a non-starter for a product.
In the article, [Stefan] enumerates a long list of problems that going from project to product raises, as well as how he addressed them. The API issue was solved by implementing his own service, which acts as a middleman between the official API and his customers. A nice plexiglass and sheet-metal frame serves to protect the display, too. Design changes were made as well, not only to provide better functionality but to make manufacturing easier. [Stefan] also relates a tale of woe with regard to getting the display’s app into the app stores, something that few of us have to deal with when we’re just fiddling around with something on the bench.
All in all, [Stefan] does a great job walking us through the trials and tribulations of bringing a product to market. There are similar lessons in this production run scale-up, too, but with an entirely different level of project complexity.
Apple Archeology: The Future Once Had Server Side Computing In It
To read the IT press in the early 1990s, those far-off days just before the Web was the go-to source of information, was to be fed a rosy vision of a future in which desktop and server computing would be a unified and powerful experience. IBM and Apple would unite behind a new OS called Taligent that would run Apple, OS/2, and 16-bit Windows code, and coupled with UNIX-based servers, this would revolutionise computing.
We know that this never quite happened as prophesied, but along the way, it did deliver a few forgotten but interesting technologies. [Old VCR] has a look at one of these, a feature of the IBM AIX, which shipped with mid-90s Apple servers as a result of this partnership, in which Mac client applications could have server-side components, allowing them to offload computing power to the more powerful machine.
The full article is very long but full of interesting nuggets of forgotten 1990s computing history, but it’s a reminder that DOS/Windows and Novell Netware weren’t the only games in town. The Taligent/AIX combo never happened, but its legacy found its way into the subsequent products of both companies. By the middle of the decade, even Microsoft had famously been caught out by the rapid rise of the Web. He finishes off by creating a simple sample application using the server-side computing feature, a native Mac OS application that calls a server component to grab the latest Hacker News stories. Unexpectedly, this wasn’t the only 1990s venture from Apple involving another company’s operating system. Sometimes, you just want to run Doom.
