Double-Slit Time Diffraction At Optical Frequencies
The double-slit experiment, first performed by [Thomas Young] in 1801 provided the first definitive proof of the dual wave-particle nature of photons. A similar experiment can be performed that shows diffraction at optical frequencies by changing the reflectivity of a film of indium-tin-oxide (ITO), as demonstrated in an April 2024 paper (preprint) by [Romain Tirole] et al. as published in Nature Physics. The reflectivity of a 40 nm thick film of ITO deposited on a glass surface is altered with 225 femtosecond pulses from a 230.2 THz (1300 nm) laser, creating temporal ‘slits’.
Interferogram of the time diffracted light as a function of slit separation (ps) and frequency (THz). (Credit: Tirole et al., Nature Physics, 2024)
The diffraction in this case occurs in the temporal domain, creating frequencies in the frequency spectrum when a separate laser applies a brief probing pulse. The effect of this can be seen most clearly in an interferogram (see excerpt at the right). Perhaps the most interesting finding during the experiment was how quickly and easily the ITO layer’s reflectivity could be altered. With ITO being a very commonly used composition material that provides properties such as electrical conductivity and optical transparency which are incredibly useful for windows, displays and touch panels.
Although practical applications for temporal diffraction in the optical or other domains aren’t immediately obvious, much like [Young]’s original experiment the implications are likely to be felt (much) later.
Featured image: the conventional and temporal double-slit experiments, with experimental setup (G). (Credit: Tirole et al., Nature Physics, 2024)
This Week In Security: Quantum RSA Break, Out Of Scope, And Spoofing Packets
Depending on who you ask, the big news this week is that quantum computing researchers out of China have broken RSA. (Here’s the PDF of their paper.) And that’s true… sort of. There are multiple caveats, like the fact that this proof of concept is only factoring a 22-bit key. The minimum RSA size in use these days is 1024 bits. The other important note is that this wasn’t done on a general purpose quantum computer, but on a D-Wave quantum annealing machine.
First off, what is the difference between a general purpose and annealing quantum computer? Practically speaking, a quantum annealer can’t run Shor’s algorithm, the quantum algorithm that can factor large numbers into primes in a much shorter time than classical computers. While it’s pretty certain that this algorithm works from a mathematical perspective, it’s not at all clear that it will ever be possible to build effective quantum computers that can actually run it for the large numbers that are used in cryptography.
We’re going to vastly oversimplify the problem, and say that the challenge with general purpose quantum computing is that each q-bit is error prone, and the more q-bits a system has, the more errors it has. This error rate has proved to be a hard problem. The D-wave quantum annealing machine side-steps the issue by building a different sort of q-bits, that interact differently than in a general purpose quantum computer. The errors become much less of a problem, but you get a much less powerful primitive. And this is why annealing machines can’t run Shor’s algorithm.
The news this week is that researchers actually demonstrated a different technique on a D-wave machine that did actually factor an RSA key. From a research and engineering perspective, it is excellent work. But it doesn’t necessarily demonstrate the exponential speedup that would be required to break real-world RSA keys. To put it into perspective, you can literally crack a 22 bit RSA key by hand.
Continue reading “This Week In Security: Quantum RSA Break, Out Of Scope, And Spoofing Packets” →
MOTU Audio Interface Resurrected After Some Reverse Engineering
These days, when something electronic breaks, most folks just throw it away and get a new one. But as hackers, we prefer to find out what the actual problem is and fix it. [Bonsembiante] took that very tack when a MOTU brand audio interface wasn’t booting. As it turns out, a bit of investigative work led to a simple and viable fix.
The previous owner had tried to get the unit fixed multiple times without success. When it ended up on [Bonsembiante]’s bench, reverse engineering was the order of the day. Based around an embedded Linux system, there was lots to poke and prod at inside, it’s just that… the system wasn’t booting, wasn’t showing up over USB or Ethernet, or doing much of anything at all.
Extracting the firmware only revealed that the firmware was actually valid, so that was a dead end. However, after some work following the boot process along in Ghidra, with some external help, the problem was revealed. Something was causing the valid firmware to fail the bootloader’s checks—and with that fixed, the unit booted. You’ll have to read the article to get the full juicy story—it’s worth it!
We’ve seen [Bonsembiante’s] work here before, when they turned an old ADSL router into a functioning guitar pedal. Video after the break.
Continue reading “MOTU Audio Interface Resurrected After Some Reverse Engineering” →
Overcomplicating The Magnetic Compass For A Reason
Some inventions are so simple that it’s hard to improve them. The magnetic compass is a great example — a magnetized needle, a bit of cork, and a bowl of water are all you need to start navigating the globe. So why in the world would you want to over-complicate things with something like this Earth inductor compass? Just because it’s cool, of course.
Now, the thing with complication is that it’s often instructive. The simplicity of the magnetic compass masks the theory behind its operation to some degree and completely fails to deliver any quantitative data on the Earth’s magnetic field. [tsbrownie]’s gadget is built from a pair of electric motors, one intact and one stripped of its permanent magnet stators. The two are mounted on a 3D printed frame and coupled by a long shaft made of brass, to magnetically isolate them as much as possible. The motor is powered by a DC supply while a digital ammeter is attached to the terminals on the stator.
When the motor spins, the stator at the other end of the shaft cuts the Earth’s magnetic lines of force and generates a current, which is displayed on the ammeter. How much current is generated depends on how the assembly is oriented. In the video below, [tsbrownie] shows that the current nulls out when oriented along the east-west axis, and reaches a maximum along north-south. It’s not much current — about 35 microamps — but it’s enough to get a solid reading.
Is this a practical substitute for a magnetic compass? Perhaps not for most use cases, but a wind-powered version of this guided [Charles Lindbergh]’s Spirit of St. Louis across the Atlantic in 1927 with an error of only about 10 miles over the trip, so there’s that. Other aircraft compasses take different approaches to the problem of nulling out the magnetic field of the plane.
Continue reading “Overcomplicating The Magnetic Compass For A Reason” →
