This Week In Security: Apple Warns Users, Stripe Merchants Leak Keys, Copilot Helps Hack Itself, And Comcast Senses Movement
Apple has started sending some users push notifications warning that they have been targeted with specific malware. No specific information about the threat Apple detected is available. While multiple iOS attacks were released in spring of 2026, they all target much older versions of iOS and older hardware versions.
Users in 110 countries have received notifications recently, warning them they may have been targeted or already impacted by malware such. Apple typically uses the crash reporting mechanism for system apps to track new attack trends. The majority of users will likely never see an alert from Apple because malware with state-level capabilities like the Pegasus family is extremely expensive to develop. However, commercial availability means that some governments have deployed them against political opponents, protesters, human rights lawyers, and journalists.
If Apple pushes a security alert, it will show up as an email and a standard system notification, but also as a notification inside the Settings application. While email and notifications can be spoofed as part of phishing attempts, to date there is nothing which can generate false alerts inside Settings.
Almost universally in these cases, Apple recommends enabling “Lockdown Mode“, which adds extra protection to devices at the cost of decreased battery life and slower performance. Lockdown mode disables custom fonts on web pages, accelerated JavaScript, restricts message attachments over SMS and iMessage, and disables other common paths used by malware to steal data. Android devices offer a similar feature since Android 15 that is less comprehensive but can still provide additional safeguards for users directly at risk.
Attacking Airplane Networks
With research that will surely result in some breathless reports, researchers presented at Usenix 2026 an attack against the communications bus of a Boeing 737.
The ARINC 429 bus is a communications architecture for planes, similar to the CAN bus used in cars. Once you are connected to that bus, it can be vulnerable in the same ways cars can be vulnerable to data manipulation. In the Usenix paper, researchers discovered that one access port to the airplane communications system is easily reached from the outside of the plane, though “easily” in this context means “by airplane maintenance technicians”. The paper represents over a decade of work by the team in obtaining and building a test lab of avionics equipment to represent an actual airplane, culminating in an embedded device described as “the size of a quarter” that plugs into the communications port and provides remote access over WiFi.
It needs to be emphasized, given other recent news, that this is a piece of hardware being added to the plane which communicates over WiFi, and not a way to attack an unmodified plane via passenger WiFi!
Once part of the ARINC bus, it seems access is basically unfettered: the team describes being able to reprogram the autopilot, feed the pilot displays false data, and being able to modify the temperature and weight data shown, which could lead to miscalculations in take-off speeds with obviously catastrophic results. Fortunately, the researchers have also been working with Boeing since 2020 to address the issues being found, and the practicality of the attack in the wild remains largely theoretical. The research team has recommended removing the external ports in future aircraft, and blocking access to them physically, like with epoxy, in the current designs.
If reading security research papers is your kind of fun, be sure to check out the rest of the papers that were part of Usenix 2026.
Continue reading “This Week In Security: Apple Warns Users, Stripe Merchants Leak Keys, Copilot Helps Hack Itself, And Comcast Senses Movement” →
Spoofed Serial Number Unlocks Cricut Machine
[xssfox] recently found a Cricut Maker in an e-waste disposal. A quick scan over the device indicated it was in moderately good condition, with merely some perished rollers to contend with. The device was salvaged, with the awareness that Cricut is plenty good at disabling and locking down machines when it wishes. However, those measures didn’t stop [xssfox] from bringing it back to life.
The suspicion was that the machine had been locked out after the original owner received a warranty replacement or similar. Whatever the reason, the rollers would have to be repaired and the machine unlocked if it were ever to cut (Cricut?) again. Hooking the machine up to Cricut software showed that it was “deactivated”, so there was work to do.
The rollers were not a difficult replacement, but the hacking would take a little work. Examining the motherboard didn’t reveal any obvious EEPROMs, and the microcontroller was not one [xssfox] had the debugger to work with. Thus, attention turned to intercepting communications between the machine and the host PC over USB. This revealed the machine sending its serial number to the Cricut PC software in plain text with no checksums or encryption at all. Unlocking the machine was as easy as installing an RP2040 in between the Cricut Maker and the host PC. It was programmed to relay packets between the two and spoof the serial number in the process.
[xssfox] suspects a software-only solution may be possible, too, though hasn’t implemented one yet. We’ve featured her work before, too, like her efforts to spoof emergency traffic light preemption signals.
Self-Hosting Offline Websites
If there’s one thing that’s guaranteed in the tech world it’s that nothing is guaranteed. From AOL, Netscape, Yahoo, and MySpace, every tech empire seems to eventually fall to ruin. One method to reliably maintain information or online experiences that are lost to whims of computer users and markets is to backup, preserve, and host that information on one’s own computers, and the Kiwix project aims to help make offline backups of favorite websites.
The open-source tool started as a way for users to make their own offline backups of Wikipedia but eventually expanded into having the ability to backup many other sites as well. Wiki-type sites are generally the easiest, but it can also create backups of other sites like StackExchange so that when the Internet goes down or the site vanishes from the world, the information is preserved for use. There are plenty of guides online for setting up Kiwix as well, with it running easily on most Linux systems with or without the help of Docker, as well as versions available for Windows, Android, and Apple platforms.
Although the Kiwix software hosts the website backups, creating the backups needs to be done with another tool called Zimit to create the .zim files Kiwix uses. The Kiwix organization also hosts pre-downloaded .zim files of common websites so each user is not independently crawling Wikipedia on their own, a task that could take months on limited consumer hardware. As for what hardware to ultimately host it on, we might recommend an armageddon-proof machine like this one.
