The fully assembled RocketSwitch, with a 3D printed case on it and a USB-A connector sticking out, being held in someone's hand.
Rocket Switch – Accessibility Done With Elegance
Quite a few makers try and create devices helpful to others – today’s hack, Rocket Switch, is a lovely example of that. It’s a design by [Neil Squire] of [Makers Making Change], with a PCB that plugs onto an Adafruit Rotary Trinkey, soldering onto its exposed pads, equipping it with two headphone jacks connected to GPIOs. This is a simple design – only two headphone jacks and resistors, complete with a 3D printed case. The value is not as much in its construction, but more in what the Rocket Switch provides to its users.
This is an accessibility-enabling controller, a USB HID device which interfaces to a wide variety of headphone-jack-connectable switches. With this device, someone unable to use a computer mouse can use two tactile buttons to control their computer, either by imitating mouse clicks or by sending keypresses into accessibility software equipped a control flow for such two-switch arrangements.
Everything is open-source, and there’s an impressive amount of documentation – for 3D printing, ordering, usage, design choice explanations, and of course, a picture-peppered 15-page tutorial PDF with detailed assembly instructions for anyone who might need a Rocket Switch. Plus, [Makers Making Change] created a page where both people in need and makers with some free time can sign up to exchange these devices. It’s not the first time we see a design like this – perhaps the most famous example is Microsoft’s Xbox Adaptive Controller, something that we’ve seen a dad use to build an entertainment platform for his daughter.
Continue reading “Rocket Switch – Accessibility Done With Elegance”
Accessible Controller Plays Around With Modularity
Video games are a great way to have some fun or blow off a little steam when real life becomes laughable. But stock controllers and other inputs are hardly one size fits all. Even if you have no physical issues, they can be too big, too small, or just plain uncomfortable to hold.
[kefcom] wrote in to give us a heads up about a modular, adaptive system he designed for anyone who is unable to operate a PS3, PS4, or PC with a standard controller. The project was inspired by Microsoft’s adaptive XBOX controller and works pretty much the same way — broken-out buttons, joysticks, and other inputs all connect to a hub that unifies them into a controller the console or computer can communicate with. The major difference is that this project is open source and can be realized much more cheaply.
If you want to give this a try, [kefcom]’s project repo has step-by-step instructions for disassembling two types of wireless controllers and converting them into hubs for modular controls. He’s looking for help with design, documentation, and finding reliable suppliers for all the parts, so let him know if you can assist.
Some players need something more accessible than just broken-out buttons and full-size joysticks. Here’s an adaptive controller that uses ridged foam rollers to actuate buttons.
Dad Makes Xbox And Nintendo Work Together To Bridge The Accessibility Gap
In the last few years, console and controller manufacturers have been making great strides in accessibility engineering in order to improve the inclusiveness of people with different motor disabilities into the gaming world. One such example is the Xbox Adaptive Controller, which [Rory Steel] has used to build his daughter a fully customized controller to allow her to play Breath of the Wild on the Nintendo Switch.
His build plan is outlined in just a few Twitter videos, and sadly we don’t have a detailed walkthrough on how to build our own just yet, though he mentions plans on making such guide in the future. In the mean time, it’s not too hard to speculate on some specifics. The Adaptive Controller can use USB-C for communication, as the Switch also does with its Pro controller in wired mode. Interfacing the two is as simple as using an adapter to bridge the gap between the two vendors.
The joysticks are each wired into generic gamepads which act as the left and right sticks, each one being a separate USB input into the Adaptive Controller, while each one of the button inputs is broken out to 3.5mm jacks on its back, making them dead simple to wire to the sixteen arcade buttons surrounding the sticks. The layout might look unconventional to us, and [Rory] mentions this is simply a prototype that will be improved upon in the future after real-world testing. The size of his daughter’s smile tells us this is already a success in her eyes.
This is not the first time we’ve seen a build with the Xbox Adaptive Controller, and it’s nice to see just how well it enables parents to build their kids controllers they can use more easily, seeing as how before its introduction these kinds of controllers usually required the expertise for tearing expensive official controllers apart in ways the manufacturers never expected. We can only hope that going forward, this sort of accessibility becomes more the norm and less the exception.
[via Kotaku, thanks Itay for the tip!]
When Your Car Breaks Down, Simply Hack It Into A Simulator
When [Nishanth]’s Subaru BRZ came to a sudden halt, he was saddened by the wait to get a new engine installed. Fortunately, he was able to cheer himself up by hacking it into a car simulator in the mean time. This would have the added benefit of not being limited to just driving on the Road Atlanta where the unfortunate mishap occurred, but any course available on Forza and similar racing games.
On paper it seemed fairly straight-forward: simply tap into the car’s CAN bus for the steering, throttle, braking and further signals, convert it into something a game console or PC can work with and you’re off to the races. Here the PC setup is definitely the cheapest and easiest, with a single part required: a Macchina M2 Under the Dash kit ($97.50). The XBox required over $200 worth of parts, including the aforementioned Macchina part, an XBox Adaptive Controller and a few other bits and pieces. And a car, naturally.
https://www.notion.so/image/https%3A%2F%2Fs3-us-west-2.amazonaws.com%2Fsecure.notion-static.com%2Fd49697c6-29ae-4b4d-a27b-e2da019d32de%2FUntitled.png?table=block&id=ed4e1bf2-91c6-4494-8e0f-f10964620869&width=5120&cache=v2
The Macchina M2 is the part that listens to the CAN traffic via the OBD2 port, converting it into something that resembles a USB HID gamepad. So that’s all a matter of plug’n’play, right? Not so fast. Every car uses their own CAN-based system, with different peripherals and addresses for them. This means that with the Macchina M2 acquired, [Nishanth]’s first task was to reverse-engineer the CAN signals for the car’s controls.
At this point the story is pretty much finished for the PC side of things, but the XBox One console is engineered to only accept official peripherals. The one loop-hole here is the Adaptive Controller, designed for people with disabilities, which allows the use of alternative inputs. This also enables using a car as an XBox One controller, which is an interesting side-effect.
Continue reading “When Your Car Breaks Down, Simply Hack It Into A Simulator”
