PN26 badge
Shelf Life Extended: Hacking E-Waste Tags Into Conference Badges
Ever wonder what happens to those digital price tags you see in stores once they run out of juice? In what is a prime example of e-waste, many of those digital price tags are made with non-replaceable batteries, so once their life is over they are discarded. Seeing an opportunity to breathe new life into these displays, [Tylercrumpton] went about converting them to be the official badge of the Phreaknic 26 conference.
Looking for a solution for a cheap display for the upcoming conference badge, [Tylercrumpton] recalled seeing the work [Aaron Christophel] did with reusing electronic shelf labels. Looking on eBay, he picked up a lot of 100 ZBD 55c-RB labels for just $0.70 a piece. When they arrived, he got to work liberating the displays from their plastic cases. The long-dead batteries in the devices ended up being easily removed, leaving behind just the display and the PCB that drives it.
db9 programmerAnother hacker assisting with the badge project, [Mog], noticed that the spacing of the programming pads on the PCB was very close to the spacing of a DB9/DE9 cable. This gave way to a very clever hack for programming the badges: putting pogo pins into a female connector. The other end of the cable was connected to a TI CC Debugger which was used to program the firmware on the displays. But along the way, even this part of the project got an upgrade with moving to an ESP32 for flashing firmware, allowing for firmware updates without a host computer.
The next challenge was how to handle customizing 200 unique badges for the conference. For this, each badge had a unique QR code embedded in the back of the 3D printed case that pointed to an online customization tool. The tool allowed the user to change which of the images was used for the background, as well as input the name they wanted to be displayed on the badge. Once finished, the server would provide a patched firmware image suitable for flashing the badge. The original intent was to have stations where attendees could plug in their badge and it would update itself; however, due to some 11th hour hiccups, that didn’t pan out for this conference. Instead, [Tylercrumpton] ran the update script on his machine, and it gave him a great opportunity to interact with conference attendees as they stopped by to update their badges.
For the Phreaknic 27 badge, the plan is to once again use electronic shelf labels, but this time to utilize some of the advanced features of the tags such as the EEPROM and wireless communications. We’re eager to see what the team comes up with.
Continue reading “Shelf Life Extended: Hacking E-Waste Tags Into Conference Badges”
Supercon 2025 Badge Gets Vintage Star Trek Makeover
There are still a few days before the doors open on this year’s Hackaday Supercon in Pasadena, but for the most dedicated attendees, the badge hacking has already begun…even if they don’t have a badge yet.
By referencing the design files we’ve published for this year’s Communicator badge, [Thomas Flummer] was able to produce this gorgeous 3D printed case that should be immediately recognizable to fans of the original Star Trek TV series.
Metal hinge pin? Brass inserts? Scotty would be proud.
Although the layout of this year’s badge is about as far from the slim outline of the iconic flip-up Trek communicator as you can get, [Thomas] managed to perfectly capture its overall style. By using the “Fuzzy Skin” setting in the slicer, he was even able to replicate the leather-like texture seen on the original prop.
Between that and the “chrome” trim, the finished product really nails everything Jadzia Dax loved about classic 23rd century designs. It’s not hard to imagine this could be some companion device to the original communicator that we just never got to see on screen.
While there’s no denying that the print quality on the antenna lid is exceptional, we’d really like to see that part replaced with an actual piece of brass mesh at some point. Luckily, [Thomas] has connected it to the body of the communicator with a removable metal hinge pin, so it should be easy enough to swap it out.
Considering the incredible panel of Star Trek artists that have been assembled for the Supercon 2025 keynote, we imagine this won’t be the last bit of Trek-themed hacking that we see this weekend — which is fine by us.
A Look At All The Badge Hacks Of Supercon 2023
For those of you who’ve had the opportunity to join us in Pasadena for Supercon, you’ll know it’s a wild ride from start to finish. Singling out a single moment as our favorite is pretty much impossible, but certainly the Sunday Badge Hacking Ceremony has to rank up there. It’s the culmination of ~78 hours of intense hardware and software hacking, and that’s not even counting the pre-show work that attendees often put into their creations. Every year, without fail, this community manages to pull off badge hacks that are beyond anything we could have imagined — and we’re the ones who made the thing in the first place.
Unfortunately, in the mad rush, we’ve never had a chance to actually photograph the hacked badges and share them with the Hackaday readers. This year, at the urging of some of the badge hackers themselves, we were able to throw together a suitable overhead light at the last minute and actually snapped shots of each badge after it was presented to the audience.
The resulting images, sorted by badge hacking category, are below. While some proved difficult to photograph, especially with an impromptu setup, we’re happy to at least have a complete record of this year’s creations. Hopefully we’ll be able to improve on our technique for 2024 and beyond. If yours shows up, or if you’d like to share your appreciation, sound off in the comments below!
Continue reading “A Look At All The Badge Hacks Of Supercon 2023”
3D render of the badge programming adapter PCB
Supercon 2022 Badge Gets A Tinkering Helper Add-on
Are you one of the lucky ones to own a Hackaday Supercon 2022 badge? Would you like to make it even easier to program than it already is? [brokebit] has exactly the project you might’ve been dreaming of all along — it’s a Supercon 2022 Badge programming adapter. With pass-through for all badge pins, four buttons, a total of ten DIP switches and four LEDs, the sheer IO of this add-on makes good use of the badge’s expansion header. But that’s not all, as there’s a USB-UART converter accessible through a MicroUSB socket.
Using mostly through-hole components, this board won’t leave you digging through parts drawers for exotic buttons or pin headers; most everything is jellybean. The pass-through capability of the adapter means that other badge add-ons will be compatible and you can even use this adapter to debug them, with DIP switches helping you disconnect whatever onboard circuitry interferes. For instance, if you’re not looking for USB-UART functionality provided by the classic CP2102, the dual DIP switches are right there for you to disconnect it on the fly.
The board is 6 layers, but since the quoted price was the same as a 4-layer board, it made for a more comfortable layout. Want a refresher on the badge? Here you go, and here’s our write-up about it before Supercon. Hackers have been stretching the limits of what the 2022 badge can get done — here’s a punch card reader, for instance.
2022 Supercon: Schedule Released, And [Odd Jayy]
It’s finally time! We’ve put together the 2022 Supercon Schedule, and you can check out all the talks, workshops, and events in one place – right now.
Badge hacking heating up (photo by @hackerwarehouse)
It all starts off with breakfast on Friday morning to power you up for a full day of badge hacking, workshops, and general mixing and mingling before the Friday night party. Fridays are significantly less formal, but swing by Supplyframe HQ any time to get registered, get your badge, and get a mellow head start on Supercon.
Saturday morning, the talks begin! After a brief introduction and welcome, keynote speaker Joe Grand takes the stage to kick things off. And from then on, it’s two tracks of talks on two stages until your brain explodes. Or at least until the Hackaday Prize Awards ceremony at 7:00 PM, followed by the awards after-party.
Pull yourself out of bed Sunday morning for another full day of stellar talks. And squeeze in some more last minute badge-hacking time somehow, because we close up Sunday evening with the always entertaining badge hacking contest and awards.
Jorvon [Odd Jayy] Moss to Speak
Plus, we’ve got one last bit of great news: Jorvon [Odd Jayy] Moss is giving a talk on his adventures in making companion robots, and his latest forays into adding more intelligence into his animatronic and artistic creations.
So if you haven’t bought your tickets yet, do it. ‘Nuff said. See you at Supercon!
And if you’re not able to make it live, all of the talks on the LACM Stage will be streamed live on our YouTube channel, and you can join in the discussion over at the Hackaday Discord server or on Hackaday.io’s Supercon Chat channel. And all the talks that we can’t stream, we’re recording for later release, so you can always catch up later.
The 2022 Supercon Badge Is A Handheld Trip Through Computing History
Over the last several years, there’s been a trend towards designing ever more complex and powerful electronic event badges. Color displays, sensors, WiFi, USB, Bluetooth — you name it, and there’s probably a con badge out there that has packed it in. Even our own 2019 Supercon broke new ground with the inclusion of a Lattice LFE5U-45F FPGA running a RISC-V core. Admittedly, observing this unofficial arms race has been fascinating. But as we all know, a hacker isn’t defined by the tools at their disposal, but rather the skill and imagination with which they wield them.
So this year, we’ve taken a slightly different approach. Rather than try and cram the badge with even more state of the art hardware than we did in 2019, we’ve decided to go back to the well. The 2022 Supercon badge is a lesson in what it means to truly control a piece of hardware, to know what each bit of memory is doing, and why. Make no mistake, it’s going to be a challenge. In fact, we’d wager most of the people who get their hands on the badge come November 4th will have never worked on anything quite like it before. Folks are going to get pulled out of their comfort zones, but of course, that’s the whole idea.
Continue reading “The 2022 Supercon Badge Is A Handheld Trip Through Computing History”
Remoticon 2021 // Jeroen Domburg [Sprite_tm] Hacks The Buddah Flower
Nobody likes opening up a hacking target and finding a black epoxy blob inside, but all hope is not lost. At least not if you’ve got the dedication and skills of [Jeroen Domburg] alias [Sprite_tm].
It all started when [Big Clive] ordered a chintzy Chinese musical meditation flower and found a black blob. But tantalizingly, the shiny plastic mess also included a 2 MB flash EEPROM. The questions then is: can one replace the contents with your own music? Spoiler: yes, you can! [Sprite_tm] and a team of Buddha Chip Hackers distributed across the globe got to work. (Slides here.)
[Jeroen] started off with binwalk and gets, well, not much. The data that [Big Clive] dumped had high enough entropy that it looks either random or encrypted, with the exception of a couple tiny sections. Taking a look at the data, there was some structure, though. [Jeroen] smelled shitty encryption. Now in principle, there are millions of bad encryption methods out there for every good one. But in practice, naive cryptographers tend to gravitate to a handful of bad patterns.
Bad pattern number one is XOR. Used correctly, XORing can be a force for good, but if you XOR your key with zeros, naturally, you get the key back as your ciphertext. And this data had a lot of zeros in it. That means that there were many long strings that started out the same, but they seemed to go on forever, as if they were pseudo-random. Bad crypto pattern number two is using a linear-feedback shift register for your pseudo-random numbers, because the parameter space is small enough that [Sprite_tm] could just brute-force it. At the end, he points out their third mistake — making the encryption so fun to hack on that it kept him motivated!
Decrypted, the EEPROM data was a filesystem. And the machine language turned out to be for an 8051, but there was still the issue of the code resident on the microcontroller’s ROM. So [Sprite_tm] bought one of these flowers, and started probing around the black blob itself. He wrote a dumper program that output the internal ROM’s contents over SPI. Ghidra did some good disassembling, and that let him figure out how the memory was laid out, and how the flow worked. He also discovered a “secret” ROM area in the chip’s flash, which he got by trying some random functions and looking for side effects. The first hit turned out to be a memcpy. Sweet.
[Neil555]’s Rosetta Stone
Meanwhile, the Internet was still working on this device, and [Neil555] bought a flower too. But this one had a chip, rather than a blob, and IDing this part lead them to an SDK, and that has an audio suite that uses a derivative of WMA audio encoding. And that was enough to get music loaded into the flower. (Cue a short rick-rolling.) Victory!
Well, victory if all you wanted to do was hack your music onto the chip. As a last final fillip, [Sprite_tm] mashed the reverse-engineered schematic of the Buddha Flower together with [Thomas Flummer]’s very nice DIY Remoticon badge, and uploaded our very own intro theme music into the device on a badge. Bonus points? He added LEDs that blinked out the LSFR that were responsible for the “encryption”. Sick burn!
Editor’s Note: This is the last of the Remoticon 2 videos we’ve got. Thanks to all who gave presentations, to all who attended and participated in the lively Discord back channel, and to all you out there who keep the hacking flame alive. We couldn’t do it without you, and we look forward to a return to “normal” Supercon sometime soon.
