A circuit board card is shown, with a blue panel on one side. On the panel are switches and an RS-232 port.
Spoofing An Emergency Traffic Preemption Signal
There’s a well-known movie trope in which a hacker takes control of the traffic lights in a city, causing general mayhem or creating a clear getaway path. Unlike many Hollywood representations of hacking, this is actually possible in principle; many cities install Emergency Vehicle Preemption (EVP) systems in their traffic signals to turn them green when an emergency vehicle is approaching. To see what it would actually take to control one of these, [xssfox] reverse-engineered a Strobecom II EVP system.
Most EVP systems, particularly older ones, use a strobing infrared light to alert a traffic signal to an approaching emergency vehicle. To avoid misuse, vehicles often encode a vehicle ID in the infrared signal. There have been some claims that a Flipper Zero can trigger these systems, but none that were well-verified, and probably with good reason; anyone actually trying this against a live system is courting serious legal trouble. To see whether this was actually possible [xssfox] obtained real hardware and tried to reverse-engineer the infrared protocol.
There are two main manufacturers for optical EVP systems: GTT Opticom and Tomar Strobecom. [xssfox] managed to buy a Tomar power supply which handled the processing for signal transmission, and which worked with Opticom systems. Looking at the output of this revealed that it encoded data by skipping pulses, which should be simple enough for Flipper Zero to replicate.
To reverse-engineer the Strobecom protocol, [xssfox] managed to buy a Strobecom optical signal processor, which would normally detect an emergency signal. This worked by modulating the length of infrared pulses. After some brute-forcing, a transmitter using an Arduino Nano and an infrared LED managed to activate the preemption signal, and even to transmit a vehicle ID. It seems that Strobecom systems, at least, are fairly demanding in terms of the signals they accept; signals had to be precisely timed, and in at least some systems, a valid vehicle ID would be needed to change the light.
If you’d like to learn more, we’ve gone into the technology of North American traffic signals before.
The Clever Design Behind Everyday Traffic Poles
Ever stopped at a red light and noticed something odd about the poles holding up the traffic lights? Look closer next time—many of them appear to hover just above the concrete, anchored by visible bolts. This video below explains it all. It’s not a job left unfinished. It is actually clever design, and all about functionality and easy maintenance. Let’s break down why engineers prefer this so-called ‘floating’ base plate setup.
At first, you might think mounting poles directly into concrete would be more stable—after all, that’s how heavy columns are often installed. But traffic light poles are lightweight, hollow, and face constant wind pressure. Instead of brute stability, they need flexibility and precise alignment. Enter the standoff base plate. By resting on leveling nuts, these poles can be fine-tuned for perfect verticality, even when the ground shifts slightly over time. That’s critical for keeping your 30-foot pole from leaning like the Tower of Pisa.
The open design also simplifies maintenance. If the pole tilts after years of wear, it takes just a few nut adjustments to fix it—no heavy cranes required. Plus, the gap helps prevent moisture buildup, reducing corrosion. So next time you’re waiting at an intersection, you’ll know it’s not just clever engineering—it’s practical street smarts. If you’re an infrastructure nut, this slightly older article might spark your interest.
Continue reading “The Clever Design Behind Everyday Traffic Poles”
Tech In Plain Sight: What Does A Yellow Light Mean?
Ghigleri’s traffic light
The traffic light is a ubiquitous feature of modern life and is quite old — dating back to 1868 London, although that device was a modified railroad semaphore operated by a policeman, but it was the same idea. The initial test of the signal proved disastrous.
The semaphore had gas lamps to illuminate the signs in the dark. A gas leak caused one of the lamps to explode, badly burning the operator and ending the nascent invention for a while. In 1910, American inventor Ernest Sirrine worked out an automatically controlled traffic signal. Two years later, Lester Wire, a police officer, developed a different version powered by overhead trolley wires to light the signal. A 1917 patent by William Ghiglieri also had two lights — red and green. But where was the yellow light?
Continue reading “Tech In Plain Sight: What Does A Yellow Light Mean?”
A scaled down version of a pedestrian crossing signal
Don’t Walk Past This 3D Printed Pedestrian Crossing Light
There’s just something so pleasing about scaled-down electronic replicas, and this adorable 3D printed pedestrian crossing light by [sjm4306] is no exception.
Although a little smaller than its real-world counterpart, the bright yellow housing and illuminated indicators on this pedestrian lamp are instantly recognizable due to their ubiquitous use throughout the United States. The handful of printed parts are held together using friction alone, which makes assembly a literal snap. The ‘safety grill’ with its many angles ended up being one of the most tedious parts of the build process, but the effort was definitely justified, as it just wouldn’t look right without it.
A suitably minuscule ATtiny85 drives a pair of LED strips that effectively mimic the familiar symbols for ‘Walk’ and ‘Don’t Walk’. [sjm4306] has designed the board and case in such a way to accommodate a variety of options. For example, there’s just enough room to squeeze in a thin battery, should you want to power this contraption on-the-go. If you don’t have an ATtiny85 on hand, the board also supports an ATmega328p or even an ESP8266.
All the build details are available over on Hackaday.io. While it’s billed as a ‘night light’, we think this could be an awesome platform for an office toy, similar to this office status light project. Or if you’ve somehow already got your hands on a full-size pedestrian lamp, why not hook it up to the Internet?
Continue reading “Don’t Walk Past This 3D Printed Pedestrian Crossing Light”
Mike Ossmann And Dominic Spill: IR, Pirates!
Mike Ossmann and Dominic Spill have been at the forefront of the recent wave of software-defined radio (SDR) hacking. Mike is the hardware guy, and his radio designs helped bring Bluetooth and ISM-band to the masses. Dominic is the software guy who makes sure that all this gear is actually usable. The HackRF SDR is still one of the best cheap choices if you need an SDR that can transmit and receive.
So what are these two doing on stage giving a talk about IR communication? Can you really turn traffic lights green by blinking lights? And can you spoof a TV remote with a cardboard cutout, a bicycle wheel, and a sparkler? What does IR have to do with pirates, and why are these two dressed up as buccaneers? Watch our video interview and find out, or watch the full talk for all of the juicy details.
Continue reading “Mike Ossmann And Dominic Spill: IR, Pirates!”
Reverse Engineering Traffic Lights With Software Defined Radio
Construction crews tearing up the street to lay new internet fiber optic cable created a unique opportunity for [Bastian Bloessl]. The workers brought two mobile traffic lights to help keep the road safe while they worked. [Bastian] had heard that these lights use the 2 meter band radios, so he grabbed his RTL-SDR USB stick and started hacking. Mobile traffic lights are becoming more common in Europe. They can be controlled by a clock, traffic volume via an on-board camera, wire or radio. They also transmit status data, which is what [Bastian] was hoping to receive.
A quick scan with GQRX revealed a strong signal on 170.760 MHz. Using baudline and audacity, [Bastian] was able to determine that Audio Frequency Shift Keying was used to modulate the data. He created a simple receiver chain in GNU radio, and was greeted with a solid data stream from the lights. By watching the lights and looking at the data frames, [Bastian] was able to determine which bits contained the current light status. A quickly knocked up web interface allowed him to display the traffic light status in real-time.
It’s a bit scary that the data was sent in plaintext, however this is just status data. We hope that any command data is sent encrypted through a more secure channel.
Continue reading “Reverse Engineering Traffic Lights With Software Defined Radio”
