Young Maker Mixes Traditional Japanese Construction With Modern Art
We’re Makers. By definition, we make things. Some of us prefer to build from scraps, while others like to make their own IC’s in their garage. [Make With Miles] on the other hand prefers one of the oldest types of making around: woodworking. And in this build, he goes a step further by using a very old Japanese method of woodworking called Kumiko to build a Stratocaster style electric guitar. The results are absolutely stunning as you can see in the video below.
Inspired by a challenge put forth by [The Modern Maker Podcast] to build a woodworking project that ties into another hobby that isn’t related to woodworking, [Miles] knocked it out of the park by including several art forms in this one-off Strat.
The centerpiece of this guitar build is the Kumiko style of construction used within the body. Kumiko is a Japanese method of assembling wood without the use of fasteners. Developed around 600-700AD, Kumiko is as much a construction method as an art form. [Miles] went further by filling the Kumiko framework with blackened epoxy resin which was then sanded and polished. Decals bring the headstock into the motif, but the attention to details goes much, much further. Be sure to watch the video so you can get an appreciation for the high level of workmanship that this young man displays.
That’s right- [Miles] isn’t a maker with decades of experience. In fact in 2017, one of his YouTube videos was “12 yr Old Builds a Row Boat!!!” [Miles], our hats are off to you and we look forward to seeing your art progress, for you truly have commanded the attention of the maker community that you are so rightfully part of.
Just as [Miles]’ guitar hides some great hacks, so does this guitar with Hot Swappable pickups. Thanks to [Keith] for sending this on to the Tip Line!
Continue reading “Young Maker Mixes Traditional Japanese Construction With Modern Art” →
A Modern But Classic Enigma Machine
Hacking has always brought more good to the world than not hacking. The successful efforts of the Allies during World War II in deciphering the Enigma machine output still reminds us of that. Today, the machine is a classic example of cryptography and bare-metal computing.
We have covered quite a few DIY Enigma machines in the past, yet 14 years old [Andy] really impressed us with his high school science fair project, a scratch built, retro-modern Enigma machine.
Continue reading “A Modern But Classic Enigma Machine” →
FlowFree Goes Life Sized At Maker Faire NY
Maker Faire 2013SetupWillow Glen MakersTeam PathfinderFlow*26
What began as a smartphone game turned into a Maker Faire New York 2013 project for the [Willow Glen Makers]. FlowX26 is a life sized version of the game FlowFree. [The Willow Glen Makers] wanted to build an extendable, easy to set up grid of floor tiles to emulate the game. A CNC machine was employed to create a plywood framework. Not visible in the picture is the fact that each cross member is cut slightly concave.  This concavity allows the clear plastic top to deflect just enough to activate a micro switch inside the tile. The switch sends a signal to the tile’s Arduino Mega controller. The Mega then uses this data to control an array of RGB LEDs.
The next problem was interconnection and communication between the tiles. [The Makers] used copper tape, along with a 3D Printed latch system between each tile side. Six connections per side allow power and data to be transmitted throughout the grid.
Continue reading “FlowFree Goes Life Sized At Maker Faire NY” →
