This is the fourth generation MIDIbox sequencer which has a features set that’s several screens long. We’ve embedded the teaser video of this 16-track marvel after the break. You can use it via a traditional MIDI connection or with USB. Standalone Ethernet features are also in the works. It’s fully documented and you can etch your own PCB if you’re brave but it might be easier to get in on the group PCB buy if you just have to have one of these. There’s no all-in-one kit, but that will just make the taste of success sweeter once your soldering iron cools down.
