Making Airsoft Guns Far More Potent
airsoft_laser_rifle
[Drake] wrote in to share his recent project, which involves repurposing an Airsoft rifle that was sitting around, collecting dust. Airsoft guns as a whole are not all that impressive, but convert your Airsoft gun into a laser rifle, and we’re all ears.
His laser blaster is honestly pretty straightforward as far as laser projects go, but we just couldn’t resist. He pulled apart the Airsoft gun, removing all of the “airy” bits, leaving just the trigger behind. He added a 9v battery and a linear power supply to the gun, wiring them up to a 700mW laser diode from what we hope was a broken Blu-ray burner.
In the obligatory “look at what I can destroy with my laser gun” video embedded below, [Drake] shows off his gun’s potency at various ranges, popping balloons from 35 feet away. He even shows off the laser’s usefulness as a light pen for glow in the dark surfaces.
While his modifications are nothing we haven’t seen before, his gun is far more accessible than others we have featured.
Have any cool high-powered laser projects of your own? Share them with us in the comments.
Continue reading “Making Airsoft Guns Far More Potent”
The Engineering Guy Explains Fiber Optics
engineering_guy_fiber_optics
[Bill the “Engineer Guy” Hammack] is back with another lesson in the science behind the technology we know and love, but might not fully understand. This time around he discusses fiber optic cabling and how it is used to relay data across distances both small and large.
He starts off by showing how laser light can be easily transmitted from one end of an audio-grade fiber optic cable to the other. To show us how this is accomplished, he sets up a simple table top demonstration involving a bucket, some propylene glycol, and a green laser pointer. The bucket has been modified to include a clear window at one side and a spout at the other. The laser is carefully lined up, and when the spout is unplugged, a steady stream of propylene glycol is released into a second bucket. As [Bill] explains, the laser stays within the stream of fluid due to total internal reflection, and can be seen shining in the second bucket.
[Bill] also discusses how fiber optics were employed in the first transatlantic telecommunications cable, as well as how pulse code modulation was used to send analog voice data over the undersea digital link.
As always, [Bill’s] video is as entertaining as it is enlightening, so be sure to check it out below.
Continue reading “The Engineering Guy Explains Fiber Optics”
Photographing Near-space Objects We’re Not Supposed To Know About
[Thierry Legault] doesn’t just look up at the stars, the uses a motorized telescope base of his own making to track and photograph secret objects orbiting the earth. What do we mean by ‘secret objects’? Spy stuff, of course.
Last month he captured some video of the X-37B, an unmanned and secretive reusable spacecraft (read: spy shuttle) which is operated by the United States Air Force. That was back on the 21st of May but a few nights later he also saw the USA-186, an optical reconnaissance (Keyhole) satellite.
After trying to cope with manual tracking using the RC control seen above [Thierry] set out to upgrade his equipment. He ended up designing his own software package (and then released it as freeware) to automatically track the trajectory of orbiting objects. He uses a second telescope to locate the object, then dials it in with the bigger telescope. Once in frame, the software takes over.
[Wired via Dangerous Prototypes]
Quadbike: Smaller Is Faster
After three huge mutant vehicle builds, [Tom Wilson] thought: “why not build another?” This time he decided to weld together a (comparatively) smaller more agile two-seater he calls the Boxer. We covered [Tom]’s previous quadbike, Big Dog, which features a similar tube frame, full suspension, and the familiar culvert pipe wheels.  This time around [Tom] actually built an extensive jig out of plywood to ease in the build process.  The Boxer is much lighter than its predecessor, weighing in at 125lbs Vs the Big Dog’s 490lbs, and about four feet shorter.  The shorter lighter vehicle makes for a much more agile ride.  If you are interested in building your own quadbike [Tom]’s site is a really good resource with tons of detail.
We really look forward to seeing this latest creation at burning man, check out a video of the (comparatively speedy) Boxer in action after the jump!
Continue reading “Quadbike: Smaller Is Faster”
Roomba Shares All Of Its Daily Activity On The Web
tweeting_roomba
Instructables user [matchlighter] wanted to see what he could program his Roomba to do, so he decided he would make his little cleaning machine report its status on Twitter whenever something happened.
He popped open the Roomba’s case to access its serial connector, crafting a simple interface cable from some spare Cat5 he had sitting around. He added a small voltage regulator between the Roomba and his Arduino in order to protect it from the high power output present while the Roomba is charging. Once the proper bits were in place, he hooked the Roomba’s serial interface to the Arduino and attached a SparkFun WiFly shield to allow for wireless communications. After a bit of coding, the Roomba was sharing its activities with the entire world on Twitter.
Not only did he want the Roomba to tweet, but he decided that he also wanted the ability to control it from the web. He created a simple interface using a handy library he found online and was sending cleaning commands to the Roomba in short order.
While there is no video of the Roomba in action, you can check out what it is up to here, and there’s plenty of code to be had on his Instructables page.
The Passing Of Bob Pease
We are saddened by the recent passing of [Bob Pease]. You may not be familiar with the man, but his work has touched your lives in more ways than you can count. As an electronics engineer who specialized in analog components he was responsible for hardware that made some of the electronics in your life possible, and designed components that you’ve probably used if you dabble in electronic design.
EDN has a lengthy obituary celebrating his life and accomplishments. [Bob] was part of the 1961 graduating class at MIT. He started his career designing tube amplifiers before finding his way to a position at National Semiconductor about fifteen years later. Throughout his career he worked to promote education about analog electronics both through written text, and more recently as the host of Analog by Design, an online video program where a panel of experts discuss the ins and outs of electronics.
[Bob] was killed in an automobile accident on June 18th at the age of 70.
[via Make]
PLL 101
[Jeri Ellsworth] and former Commodore Computer engineer and current full time tinkerer [Bil Herd] have a little chat on skype covering the 101’s of Phase Lock Loops in this hour long video. PLL’s are handy for many applications, but their basic use is to keep clock signals in sync.
Topics covered include: Why we care, a basic explanation for the CD4046, capture ranges, and meta stability. Examples from analog tv, to clock recovery, finding falling edges and FPGA’s. This thing is jam packed full of information.
With talks of future episodes and a quick tour of [Bil’s] bench this is something to not miss. Join us after the break for the video!
Continue reading “PLL 101”
