Make Your Own Fume-extracting Glove Box
diy-clean-box
Here’s an easy to follow guide for building your own glove box. It’s a lab tool that contains the project you’re working on to keep things in or out. For instance, we could have used this a few years back when we tried to add an acrylic window to a hard drive. Instead, we ended up putting several hours of work into a cool-looking paperweight. But it will also come in handy for chemistry experiments that generate harmful or dangerous byproducts.
The picture above tells most of the story, but [Jason Poel Smith] does include several good tips about the construction in his video. He uses weather stripping along the edges of the clear container to ensure a seal. The hose is used to provide negative pressure so that no fumes leak out. We figure adding a smaller hole on the opposite side with a charcoal filter will help air pass into the chamber to serve as a fume extractor.
We’ve already seen a similar setup for a reflow oven. Perhaps this is the perfect solution to protect yourself from 3D printing fumes. We’re sure you saw the headlines about 3D printing being as bad as smoking cigarettes.
Continue reading “Make Your Own Fume-extracting Glove Box”
Hackaday Is Going To DEF CON!
EricEvenchick
This is Hackaday writer [Eric Evenchick]. He’s headed off to DEF CON, the annual hacking conference held every year at this time in Las Vegas. He’s hoping to see some cool stuff and make some networking connections that lead to a real job. If you’re not attending the conference here’s your chance to live vicariously. He’ll be writing on Thursday, Friday, and Saturday of next week (August 1-3) about all the stuff he encounters at the event.
If you are attending, keep your eyes open for him. We’re sorry that we didn’t manage to get any swag to him for handing out to loyal readers (not his fault, we’ve been a bit preoccupied). If you know of something he just shouldn’t miss email him: eric at hackaday.com. This includes invites to any awesome parties you’ve got planned.
Oh, and don’t be shy about making him pose with you for pictures…. just make sure to Tweet it to @hackaday if you do.
Resole Shoes With Old Tire Tread
resole-shoes-with-tires
These shoes are heavier than normal, they don’t grip as well as store-bought, and it’s a heck of a lot of work to make a pair for yourself. But if you do pull this one off you’ll have a great time showing everyone your custom tire tread shoe hack.
Two things motivated [Martin Melchior] to give this a try. The first is that tire tread is virtually indestructible when only supporting the weight of a person. Secondly, this reuses otherwise worn-out tires, making it a recycling project.
Pretty much all of the work has to do with getting the tread ready for use. Cutting off the sidewalls and sawing the ring of tread in half is rather easy. But then you have to split the tread off of the steel belts, which is not. [Martin] recommends using vice-grip pliers to grab the outer lay and pull it away from the tread, slicing along the belts with a utility knife as you go. Once you do have a flat strip just glue it to your shoes and cut away the excess.
We’re more into a different type of retread that actually takes you places.
I Keep My Tunes In An Ammo Can
ammo-can-boombox
Calling this a boom box is at least slightly ironic. Instead of high explosives it now carries high decibels in its new life as a self-contained sound system.
Despite the conspicuous power cord a peek inside reveals a big enough battery to keep the tunes playing for hours on end. [King Rootintootin] kept the cost on the build down since he was given the used speakers and amp by his girlfriend’s dad. The amp kicks out about 25 Watts with the battery rated at 7.2 Ah. He added a charger and routed the controls to the side of the ammo box so that it can be charged without removal. The only external component is the audio jack which connects it to the music source.
One of the suggested improvements from the Reddit thread is to add baffles inside of the enclosure so that sound from the two stereo channels doesn’t interfere with each other.
Hacklet Adds Linux Control For The Modlet Smart Outlet
modlet-for-linux-hacklet
Linux users now have a simple option for controlling the Modlet smart outlet. Hacklet is a Ruby script that can switch and read status information from Modlet.
This is the first we remember hearing about Modlet. It’s another take on controlling your appliances remotely. Unlike WeMo, which puts control of one outlet on WiFi, the Modlet uses a USB dongle to control two outlets wirelessly. It has the additional benefit of reading how much current is being used by each plug. This does mean that you need a running computer with the USB dongle to control it. But cheap embedded systems like the Raspberry Pi make this less of an issue both in up-front cost, and the price to keep it running all the time.
[Matt Colyer’s] demo video includes an unboxing of the $60 starter kit. The screen seen above shows his script pairing with the outlet. It goes on to demonstrate commands to switch it, and to pull the data from the device. He even provides an example of how to use IFTTT with the script.
Continue reading “Hacklet Adds Linux Control For The Modlet Smart Outlet”
Heart-shaped Heart Simulator
Heart
A few years ago, [Addie] over at Tymkrs put together a spooky little Halloween project: a small Propeller board that emulates the electrical signals in a heart. As a cardiac nurse, she thought her project could use a little improvement, and after two years she’s finally done. It’s a heart-shaped board that simulates electrical signals moving through the heart.
There are several key areas that conduct electrical signals through the heart – the sinoatrial node, atrioventricular node, and bundle branches all work like players in an orchestra to keep a heart beating like it should. If something goes wrong with one of these, the heart goes into tachycardia or fibrillation – not good, by any measure. [Addie]’s board simulates all the different ways a heart can go wrong with LEDs standing in for the electrical signals in a real heart. The name of the game here is to look at the LEDs and tell what state the heart is in.
The PCB heart is just one part of [Addie]’s heart simulator. The simulated heart can also plug into a neat little heart-shaped project box wired up with a solenoid, LCD display, headphone jack, and other electronics to turn this electronic heart into a complete study tool for heart rhythms. The nurses in [Addie]’s unit love the thing, and it looks like [Addie] might have a real cardiac training tool on here hands here.
Continue reading “Heart-shaped Heart Simulator”
10-drive Microserver Is The Clown Car Of The Computer Case World
ten-drive-itx-clown-car
[Coke Effekt] wanted to push his server’s storage limits to a higher level by combining ten 3 TB drives. But he’s not interested in transitioning to a larger case in order to facilitate the extra hardware. It only took a bit of hacking to fit all the storage in a mini-ITX case.
His first step was to make a digital model of his custom drive mount. This uses two 3D printed cages which will each hold five drives mounted vertically. To keep things cool the two cages are bolted to a 140mm fan. The connections to the motherboard also present some issues. He uses a two-port SATA card which plays nicely with port multipliers. Those multiplier boards can be seen on the bottom of the image above. The boards are mounted using another 3D printed bracket. Each breaks out one of the SATA ports into five connections for the drives.
[Thanks Pat]
