Green Roofs Could Help Improve Solar Panel Efficiency
There’s been a movement in architecture over the past couple of decades to help tie together large urban developments with plant life and greenery. We’ve seen a few buildings, and hundreds more renders, of tall skyscrapers and large buildings covered in vegetation.
The aesthetic is often a beautiful one, but the idea is done as much for its tangible benefits as for the sheer visual glory. Naturally, there’s the obvious boost from plants converting carbon dioxide into delicious, life-giving oxygen. However, greenery on the roofs of buildings could also help improve the output of solar installations, according to a recent study from Sydney, Australia.
Continue reading “Green Roofs Could Help Improve Solar Panel Efficiency”
A man watching money being shredded in a picture frame
Banksy-Like Stock Tracker Shreds Your Money When The Market’s Down
For anyone playing the stock market, and perhaps even more so for those investing in cryptocurrencies, watching the value of your portfolio go up and down can be a stressful experience. If you’d like to have a real-time display of your investments that adds even more stress, [Luis Marx] has got you covered. His latest project is a plexiglass case (video in German) that fills up with banknotes when your portfolio is up, and shreds those same notes when it’s down.
Inspired by an infamous Banksy artwork, [Luis] began by building a wood-and-plexiglass display case suitable for hanging on the wall in his office. He then installed a small paper shredder, modified with a servo so that it could be operated by an Arduino. Unable to find an off-the-shelf banknote dispenser, he designed and 3D-printed one, consisting of a spring-loaded tray and a motor-driven wheel.
A plastic box that dispenses a banknote
The project also includes a Raspberry Pi, programmed to fetch market data from online sources and calculate the net profit or loss of [Luis]’s portfolio. The resulting system is a rather disturbing visualization of the ups and downs of the market: having to sweep strips of green paper off your floor adds insult to the pain of losing money.
If you want a less painful way to keep track of your investments, try this Rocketship. For those interested in  traditional stock tickers, this ESP32 based one might be more to your liking.
Continue reading “Banksy-Like Stock Tracker Shreds Your Money When The Market’s Down”
Self Balancing Robot Needs A Little Work
A self-balancing robot isn’t a new idea, but we liked the aesthetics of [Maker ATOM’s] build. The use of a breadboard and a printed bracket looks good, as you can see in the video, below.
Like most first-time projects, though, there were some lessons learned. The power supply needs a little work and the range of balance compliance didn’t meet expectations. But those problems are soluble and, as usual, you often learn more from working through issues like these.
Continue reading “Self Balancing Robot Needs A Little Work”
