A Tale Of Nuclear Shenanigans From Down Under
It’s likely that among the readers of this article there will be many who collect something. Whether it’s rare early LEDs or first-year-of-manufacture microprocessors, you’ll scour the internet to find them, and eagerly await mystery packages from the other side of the world.
There’s a tale emerging from Australia featuring just such a collector, whose collection now has him facing a jail sentence for importing plutonium. The story however is not so clear-cut, featuring a media frenzy and over-reaction from the authorities worthy of Gatwick Airport. [Explosions&Fire] has a rather long video unpacking the events, which we’ve placed below the break.
Emmanuel Lidden is an element collector, someone who tries to assemble an entire Periodic Table in their collection. He ordered a range of elements from an American element collectors’ supply website, including samples of plutonium and thorium. He seems to have been unaware he was committing any crime, with the microscopic samples available from legitimate websites with no warnings attached. The case becomes murkier as the Australian authorities flagged the thorium sample and instructed the courier not to deliver it, which they did anyway. Then a raid of the type you’d expect for the terrorists who stole the plutonium in Back To The Future was launched, along with that Gatwick-esque media frenzy.
We’re inclined to agree that the penalty likely to be meted out to him for buying a sliver of a Soviet smoke detector embedded in a Lucite cube seems overly steep, but at the same time his obvious naivety over dealing in radioactive materials marks him as perhaps more than a little foolhardy. It’s something over which to ponder though, have we managed to amass anything illegal disguised as outdated devices? Have you? Perhaps it’s something to discuss in the comments.
Continue reading “A Tale Of Nuclear Shenanigans From Down Under”
Pluto’s Not A Planet, But It Is A Spectrum Analyzer
The RTL-SDR dongles get most of the love from people interested in software-defined radio, but the Pluto is also a great option, too. [FromConceptToCircuit] shares code to turn one of these radios into a spectrum analyzer that sweeps up to 6 GHz and down to 100 MHz. You can see a video of how it works below.
While it may seem that 100 MHz is a bit limiting, there’s plenty of activity in that range, including WiFi, Bluetooth, radio systems, both commercial and amateur, and even cell phones.
Continue reading “Pluto’s Not A Planet, But It Is A Spectrum Analyzer”
Command And Conquer Ported To The Pi Pico 2
A couple of months back, Electronic Arts did something uncharacteristically benevolent and released several of the old Command and Conquer games under the GPLv3. Logically, we knew that opened the doors up to the games being ported to new operating systems and architectures, but we admit that it was still a little surprising to see Command and Conquer: Red Alert running on the Raspberry Pi Pico 2.
[Charlie Birks] documented the process of getting the 1996 game up and running on the microcontroller in a series of Mastodon posts spanning a few days in March. Seeing the incremental progress made each day makes for interesting reading, as he moves from the game just barely starting up to being able to complete missions and eventually even get multiplayer going between two Picos.
As [Charlie] clarifies, he’s technically using the Pimoroni Pico Plus 2 W, which takes the RP2350B from the official Pico 2, adds 8 MB of PSRAM, and bumps the onboard flash to 16 MB. The upgraded specs and an SD card are required to get the game running, as content that would have originally been held in RAM on the computer must instead be pulled from flash.
For an even more streamlined experience, he eventually slaps the Pico Plus 2 W into the Pimoroni Pico VGA Demo Base — which provided not only an integrated SD card slot, but (as the name implies) VGA output.
It’s still early days, but [Charlie] has been pushing all of his code changes into his fork of Red Alert on GitHub for anyone who wants to play along at home. If you get his fork compiled and running on your own Pico, we’d love to hear about it in the comments.
Reverse Engineering The IBM PC110, One PCB At A Time
There’s a dedicated group of users out there that aren’t ready to let their beloved IBM PC110 go to that Great Big Data Center in the Sky. Unfortunately, between the limited available technical information and rarity of replacement parts, repairing the diminutive palmtops can be tricky.
Which is why [Ahmad Byagowi] has started a project that aims to not only collect all the available schematics and datasheets that pertain to the machine, but to reverse engineer all of the computer’s original circuit boards. Working from optical and x-ray scans, the project has already recreated the motherboard, power supply, modem, keyboard, and RAM module PCBs in KiCad.
Just last week the project released production-ready Gerbers for all the boards, but considering there have been 45+ commits to the repository since then, we’re going to assume they weren’t quite finalized. Of course, with a project of this magnitude, you’d expect it to take a few revisions to get everything right. (Hell, we’ve managed to screw up board layouts that had fewer than a dozen components on them.)
If you’d like to lend a hand, [Ahmad] says he could use the help. Beyond checking the boards for problems and reporting issues, he’s also on the hunt for any datasheets or other documentation that can be found for the PC110 or its components. It looks like there’s still schematic work that needs to be done as well, so if your idea of zen is figuring out how ~30 year old computers were wired up internally, this might be the perfect summer project for you.
Interestingly, our very own [Arya Voronova] has been working on creating a drop-in replacement motherboard for the Sony Vaio P using KiCad and imported board images. That hobbyists are now able to do this kind of work using free and open source tools is a reminder of just how far things have come in the last few years.
Thanks to [adistuder] for the tip.
An Amstrad PCW Receives A Bit Of Love
If Clive Sinclair’s genius in consumer electronics was in using ingenious hacks to make cheaper parts do greater things, then his Amstrad competitor Alan Sugar’s was in selling decade-old technology to consumers as new and exciting. His PCW series of computers are a great example, 1970s CP/M machines smartly marketed for late 1980s home offices. They were a popular choice at the time, and [Retro Recipes] has one. In  a video filmed in period standard definition he’s taking us through a repair to its Gotek drive, and then a RAM upgrade.
The repair and upgrade are fairly straightforward, the former being a failed OLED screen on the drive and the latter being the installation of a bank of DIP memory chips. The interest lies in how they cost-minimised a CP/M machine as a consumer product. The board relies heavily on custom chips as you might expect, and there’s a brief glimpse of one of those unusual 3″ floppy drives. The power supply is part of the monitor board as was often the case with Amstrad machines, and the whole thing is about as simple as it can be. The full video can be found below the break.
We’re guessing that particularly in the UK there will be plenty of PCWs still languishing in dusty attics, but surprisingly given their popularity at the time we see less of them that might be expected. There has been a significantly upgraded model on these pages though.
Continue reading “An Amstrad PCW Receives A Bit Of Love”
Emulating IPhone On QEMU
[Georges Gagnerot] has been trying to emulate iOS and run iPhone software in a virtual environment. There were a few choices, and qemu-t8030 had a number of interesting features that you can check out in his post.
The project requires a patched QEMU, and [Georges] did some basic jailbreaking techniques. The real problem, of course, was not having the Apple Silicon GPU. Older versions of iOS let you select software rendering, but that option is gone on newer versions. However, it was possible to patch the phone to still use software rendering. There are still apps that directly use Metal or OpenGL that won’t run, but that’s another problem.
There is a plan to explore forwarding GPU calls to a real device. However, that seems difficult so it will have to wait for now.
Continue reading “Emulating IPhone On QEMU”
Celebrating 30 Years Of Windows 95 At VCF
It’s been 30 years since Windows 95 launched. [Ms-Dos5] and [Commodore Z] are celebrating with an epic exhibit at Vintage Computer Festival East 2025. They had no fewer than nine computers — all period-correct machines running versions of Windows 95. The pictures don’t do it justice, so if you are near Wall, NJ, on Sunday, April 5, 2025, definitely go check out this and the rest of the exhibits at VCF.
An exhibit like this isn’t thrown together overnight.  [Commodore Z] and [Ms-Dos5] worked for months to assemble the right mix of desktops, laptops, and peripherals to showcase Windows 95. Many of the computers are networked as well – which was no easy task.
One particular Thinkpad 760e required pliers and force to remove a stuck PCMCIA modem card. After a struggle that was ultimately destructive to the card, the pair determined it was stuck due to a sticker that had effectively glued the card into the laptop. As the sticker finally gave up, the card popped itself out of the laptop.
Continue reading “Celebrating 30 Years Of Windows 95 At VCF”
