Road Trains Roam The Backroads Of Australia
Trains and the railways they run on are a great way to move lots of stuff, or lots of people, a long way. Steel wheels on steel rail can shift great loads at good speeds and railways remain a backbone of logistics for this very reason. The only problem is that they require a great deal of initial investment to build and plenty of maintenance to keep them functional over time.
These concerns can make a railway a difficult proposition when it comes to getting large amounts of goods in and out of remote areas. It’s a problem that Australia faces, with settlements far off the beaten track that are nevertheless in need of high-throughput freight connections. And if you can’t go rail, you go road… in a big way.
Continue reading “Road Trains Roam The Backroads Of Australia” →
Testing Hundreds Of Used LFP Cells Requires Some Automation
Although Li-ion cells have become a lot cheaper over the years, if you wish to buy hundreds of high-quality ones for that performance go-kart project, you may feel financially pressured into going for the option of stripping down years-old commercial battery packs instead.
While this is a financially sound option, you do have to figure out what the condition is of each cell before you happily stuff them into a new battery pack for said go-kart, as [Within Tolerance] recently did.
This is something that can be done manually, but for the 768 lithium iron phosphate (LFP) cells that were obtained for this project that’d be quite the tedious task. Hence it was decided to instead spend that time designing a system to automate this process, capable of charging, discharging, measuring and quantifying individual cells.
You can find the resulting Cell Goblin battery tester project on GitHub, which entails a custom PCB featuring an ESP32-S2 as the brains and associated software to monitor the process on a connected PC. Fortunately the issues on the PCB that are described in the video are claimed to be fixed in the repository version.
Using five of these dual-cell cell testers it was possible to run through the hundreds of cells with ten cells at a time. An internal resistance meter was also wired into the PC-based software via its UART. As of publication of the video the testing was still in progress, which gives some idea of how long it takes to work through those cells.
Continue reading “Testing Hundreds Of Used LFP Cells Requires Some Automation” →
Yellow YAG Produces Powerful Pulses In Les’ Leftover Laser
[Les] likes lasing lasers, and who doesn’t? [Les] likes larger lasers than lots of folks, with his current project being an Nd:YAG (that’s Neodymium:Yttrium Aluminum Garnet) flash pumped laser intended for tattoo removal. Like most of its ilk, the YAG crystal at the heart of that device is a rosy purple color, so when [Les] spotted a Yellow YAG with different doping promising powerful pulses, he purchased it promptly.
Specifically, the retailer was claiming a 30-50% efficiency increase for this yellow rod, thanks to cerium doping. It’s still considered an Nd:YAG, though you can label it as an Nd:Ce:YAG for clarity. The efficiency gain comes from the cerium atom taking unused energy from the flashbulb pulse — which is much broader-wavelength than the thin absorption line of the Nd ions in the rod — and giving that energy to the Nd atoms that do the lasing via fluorescence. He doesn’t try it, but reports on a paper showing these crystals can actually lase with reasonable efficiency from sunlight alone, which we’d love to see. Send us a tip if you try.
His original Nd:YAG rod produced 72.8 mJ pulses, while in the same setup with the yellow laser is peaking at 153 mJ, more than double the original output. That’s even better than the 30-50% [Les] expected, but he reckons it is because the old YAG is, well, old. The coatings break down over time, and UV light from the flashbulbs degrades the crystals too. That’s another benefit of tossing cerium in there, as apparently it acts as sunscreen for your laser rod. It lasts longer and works better, making it a no-brainer of an upgrade.
We’ve seen [Les]’s laser-based hacking before, like thisĀ  diode-laser PSU and we’re always glad to take a look with our remaining eye. We also featured his tattoo removal laser back when he started working on it, along with less-lasery projects like his crystal-growing rig.
Continue reading “Yellow YAG Produces Powerful Pulses In Les’ Leftover Laser” →
