PETG: The PLA Filament Alternative That Just Works
A typical response to the previous article on why PLA filament is so darn brittle. This has led some people to not use PLA filament at all, while others promote using PLA only for prototyping and throw-away parts, especially in light of PLA being compostable under the right conditions. For many mechanical parts, people turn to PETG.
Much like the PET polymer used for everything from food containers to drink bottles, PETG is durable, more resistant to degradation through mechanisms like hydrolysis and its filament form doesn’t need to be coddled like PLA does. PETG, on the other hand, tends to come from crude oil and shrugs at industrial composting conditions.
In terms of durability, degradation mechanisms and recyclability, is PETG the basic FDM filament which we should all just be using?
Continue reading “PETG: The PLA Filament Alternative That Just Works” →
Crowdsourcing An Investigation Into Coil Whine
If you’ve heard the high-pitched whine or buzz from an electronic device when a current-carrying inductor is vibrating, you’ll know how unpleasant it can be. It’s common in all kinds of equipment, but it’s become a particular annoyance of late in hardware like PC power supplies, GPUs, and cooling pumps. There is plenty of hearsay on the web about which parts whine and which don’t, and [Lowell Wood] wants to get to the bottom of it.
To track the issue, [Lowell] has put together the Coil Whine Database. It accepts user reports on hardware, regarding the level at which coil whine is present. A score of 0 is given to a part that is inaudible in a quiet room, with higher scores representing higher sound levels. A part scored at 2 is audible working at a desk with the computer under load; a part scored at 4 is audible even when the machine or device is at idle.
For now, the database is largely empty—[Lowell] has just opened submissions, adding a report on their own ROG Astral RTX 5080 card for good measure. If you want to submit a report on a unit, either silent or noisy, that’s simple enough—just fill in the coil whine report form. Over time, submissions will hopefully grow, and it will be easier to get a good idea of what equipment whines and what is likely to operate silently out of the box.
The database aims to present a guide to what parts whine, and how much, noting that any given population of devices tends to vary. To that end, any given device won’t be reported on publicly until it receives at least 5 reports. To counter bias, reports of silent parts will be weighted higher, since it’s unlikely that people happy with their quiet hardware will be rushing to research this issue or report it to a database. Relevant files to the project are available on GitHub for the curious.
This database could be a great boon to the brigade of PC builders out there who like their machines to be as silent as possible. If that sort of thing appeals to you, it’s probably time you started researching passive cooling as well…
open task light
Sliding Into Perfection: The Open Task Light
A few years ago Dyson released a desk lamp that could slide up and down, in and out, balancing itself at every position. [Steven Bennett] saw that lamp and wanted to make his own. From this passion, the Open Task Light was born.
We covered the prototype of the Open Task Light back in 2023, and the project is a superb example of iteration. In his 15-part video series on the lamp, you can watch him take on each new aspect of the light, improving the mechanisms, electronics, and production. All those small changes add up to this beautifully finished product.
The first thing you’ll notice about the lamp is how little there is to notice: just a pair of extruded aluminum rails with a lamp head on one end and some rollers in the middle. Look a little closer at the rail and you’ll find a PCB running its length, feeding the lamp through pogo pins and leaving no exposed wires. The lamp uses a heat pipe to dump the LED’s heat, again hidden inside the aluminum extrusion. An ESP32 talks to a dedicated LED driver that runs a Cree high-CRI LED. The base comes in several variations for freestanding use or clamping to a table, and it rides on bearings so it can rotate as freely as the lamp’s other axes of movement.
The original lamp this was inspired by carries a hefty price tag, and while the 50-plus-part BOM on this one adds up, it still comes in at well under half the price of its inspiration. The best part: the Open Task Light is open. You can make it your own, head over to [Steven Bennett]’s GitHub to check out the parts. He has also published a well-documented guide on assembling the Open Task Light.
Given the incredible work [Steven] has put into his lamp, we can’t wait to see his next passion project.
Continue reading “Sliding Into Perfection: The Open Task Light” →
