Matthias Wandel Hates CNC Machines In Person
Prolific woodworking YouTuber [Matthias Wandel] makes some awesome mechanical contraptions, and isn’t afraid of computers, but has never been a fan of CNC machines in the woodshop. He’s never had one either, so until now he couldn’t really talk. But he had the parts on hand, so he built a wooden CNC router. It’s lovely.
The router itself is what 3D printer folks would call a bed-slinger, and it’s cobbled together out of scrap plywood. Some of the parts have extra holes drilled in them, but “measure once, drill twice” is our motto, so we’re not one to judge. He spends a lot of time making “crash pads” that keep the frame from destroying itself while he’s building it – once the CNC is actually controlling things with the limit switches, we presume they won’t be necessary, but their design is fun anyway.
If you’re at all interested in CNC machines, you should give this video a watch. Not because it’s done the “right” way, but because it’s a CNC that’s being built on a budget from first principles, by an experienced wood builder, and it’s illuminating to watch him go. And by the end of the video, he is making additional parts for the machine on the machine, with all the holes in the right places, so he’s already stepping in the right direction.
He doesn’t love digital design and fabrication yet, though. If you’re making one-offs, it probably isn’t worth the setup time to program the machine, especially if you have all of his jigs and machines at your disposal. Still, we kind of hope he’ll see the light.
Of course, this isn’t the first wooden CNC router we’ve seen around these parts, and it probably won’t be the last. If you want to go even more fundamental, [Homo Faciens]’s series of CNC machines is a lovely mashup of paperclips and potential. Or, if refinement is more your style, this benchtop machine is the bee’s knees.
Continue reading “Matthias Wandel Hates CNC Machines In Person”
Customize Forstner Bits For Fidget Spinner Explosions
[Matthias Wandel] is a woodworker par excellence. He’s the guy behind all those wooden gear contraptions, he made cove molding on a table saw, and if the phrase, ‘don’t do this unless you know what you’re doing’ applies to anyone, it applies to [Matthias]. Now he’s getting into the fidget spinner craze, but there’s a problem in the workshop: [Matthias] couldn’t find the right sized drill bit, so he modified a Forstner bit to contain the heart of a spinner.
[Matthias] has a few roller skate bearings, which are 22mm in diameter. However, the closest drill to this size was 7/8″, or 22.23mm. A drill can be ground down, so the bit was chucked into a hand drill and taken over to the bench grinder. As with most things [Matthias] demonstrates, you shouldn’t do this unless you know what you’re doing. [Matthias] does.
With the bit ground down to 22mm, [Matthias] drilled a hole in a piece of wood, inserted the bearing, and completed an epic quest that was his destiny. There is no use for fidget spinners, so [Matthias] decided to make this one explode. After cutting several notches in this wooden spinner, [Matthias] applied shop air liberally and spun the spinner up until it fell apart.
You can check out the video of the fidget spinner carnage below, or check out [Matthias]’ write-up here.
Continue reading “Customize Forstner Bits For Fidget Spinner Explosions”
Hackaday Links: December 11, 2016
We have a contest going on right now challenging you to do the most with 1 kB of data. If you want to get into this, here’s how you do it for a dollar. Use the PIC12C508A. It’s an 8-pin DIP, has 768 bytes of program ROM and 25 bytes of data RAM. [Shaos] is trying to generate NTSC on this thing.
Remember that Internet of Cookie Oven Kickstarter from the links post a few weeks ago? It was funded. It has a heating element that is ‘more energy efficient than traditional electric elements’, and there’s still no consensus over how a resistive heating element can be more efficient. It’s either 100% efficient, or 0% efficient, depending on how you look at it.
[Matthias Wandell], master of wood gears recently built a 20″ bandsaw from scratch. It’s a wood frame, wood wheels, a (currently) underpowered motor, and a few bits of metal and rubber. The video build log is fantastic, so start here and work your way forward.
Way back in the day, Sparkfun sold a Bluetooth rotary phone. Yes, at some point in the past, phones didn’t have touchscreens or even buttons. In any event, Sparkfun hasn’t sold these phones for quite a long time. Now there’s a new hotness: giving these rotary phones a GSM module.
Here’s a little Hackaday Events housekeeping. On January 23rd, we’re going to have a meetup in NYC. We’ll also have a meetup in LA sometime in January as well. Also in January I’ll be attending CES, reporting on the latest Internet of Toasters. A week later, Hackaday will be at ShmooCon in Washington, DC. At ShmooCon last year, we had a breakfast meetup in the DC Hilton. This year, I want to do something similar. If you have an idea of what to do, leave a note in the comments.
Solenoid Engine With Woodworking Chops
Simple, elegant, and well executed. This solenoid engine build is everything we’ve come to love about [Matthias Wandel]’s work. If you don’t recognize his name you probably remember the name of his site: Wood Gears.
In what feels like an afternoon project he put together a solenoid engine. It translates the linear motion of a small solenoid into the circular motion of a flywheel. The only specialized part in this hack is the solenoid. It has a pretty long throw and includes a hinge pin at the end.
The rest is crafted mostly of wood — it is admirable how he uses that table saw like a surgeon uses a scalpel. The wooden components include a base, flywheel, very interesting bearing blocks, and a few mounting brackets to hold everything in just the right place. Add to this a coat hanger for the cam shaft, the internals of a terminal strip for the cam, some heavy gauge wire, and you’re in business. The latter two make up a clever electrical switch that synchronizes the drive of the solenoid with the flywheel.
It’s amusing to hear [Matthias] mention that this engine isn’t very practical. We still think the project has merit — it’s great for learning about how simple an engine can be, and for developing an intuitive appreciation for how great commercially available motors and engines actually are. Plus, if you can mimic these fabrication techniques you can build anything. Great work on this one [Matthias], another thing of beauty!
Check out his video below, then go back and check out his air-powered engine and of course, a hack that actually uses wood gears.
Continue reading “Solenoid Engine With Woodworking Chops”
Matthias Builds A Belt Sander
[Matthias Wandel] is the preeminent YouTube woodworker, with dozens of machines constructed from wooden gears, amazing machines that produce perfect mortise and tenons, and home-built table saws and jointers. Actually building something instead of buying it is a hallmark of [Matthias]’ channel, and he’s at it again, building his own woodworking machines. This time it’s a 1″ wide belt sander. Of course anyone can go out and simply buy one of these sanders for under $100, but what’s the point in that when you can build one out of plywood and a motor you picked out of the trash?
The design of this belt sander – just like the commercial version he’s improving upon – uses three wheels to guide the 42″ long strip of sandpaper around its course. [Matthias] is using rollerblade wheels for the front wheels. Rollerblade wheels aren’t the best shape for bearings, this can be fixed by using a table saw as a lathe. Yes, [Matthias] lathes with a table saw. He’s just that good.
The rest of the frame was carefully constructed out of plywood and powered by a 1/3 horsepower furnace fan motor pulled from the trash. There are a few interesting features that make this belt sander exceptionally useful: a rounded platen behind the belt makes sanding interior corners very easy, and is something that isn’t usually found on commercial belt sanders.
You can check out [Matthias]’ video below.
Continue reading “Matthias Builds A Belt Sander”
Hexagon Cake Cutting
Cake Knife Tessellates Cake
Rectangles? Squares? Pie slices? Who says dessert has to come in that shape? Why not triangles, circles, or even hexagons? Master of all things woodworking [Matthias Wandel] decided to solve this problem, and delved into a bit of metal working.
Using a strip of 26 gauge stainless steel, [Matthias] threw together some wood clamps in order to bend the metal into funky looking blade. He then put slits into a nice wooden handle and assembled the whole thing with a very slight positive curve, allowing you to roll the knife as you cut your confectionery.
As you can see in the following video, it works pretty well — and always, it’s a pleasure to see this man work.
Continue reading “Cake Knife Tessellates Cake”
Circular Saw To Table Saw Conversion
Corded circular saws are a dime-a-dozen at any old thrift store, yet table saws are a bit more of a costly investment — have you ever wondered if you could just make one out of a circular saw? [Matthias Wandel] did, and he just so happens to be very good at woodworking! He makes a lot of great woodworking videos to share on YouTube, and in his latest blog post, he shows us a rather elaborate way to convert a plain old circular saw, into a functional table saw.
While the concept seems simple, unless you do a lot of woodworking, you’ll probably marvel at how easily making things comes to [Matthias] — we know we did. By the end of the video he has a fully functional table saw that can raise and lower in height, and cut at different angles.
If you’re interested in making one yourself, he does a very thorough job explaining the process in his video — check it out after the break!
Continue reading “Circular Saw To Table Saw Conversion”
