Here’s an update on our earlier post about genetic programming. Altered Qualia has posted a new implementation of [Ron Alsing]’s idea. It starts with 50 polygons and then randomly changes one parameter with each optimization step. If the the change results in fewer differences from the target image, it’s kept as the new best DNA. This search method is similar to simulated annealing. The image above is the result of 1500 good mutations out of 35900 possible. The implementation lets you choose any image, but smaller means the fitness calculation is faster. It’s written in JavaScript using the <canvas> environment. You’ll definitely get better performance using newer browser builds.
[Original image by R Stevens]
[via Waxy]
